Can I change the opening direction of the door of my Samsung WF8704RSW washing machine? Looking at the the machine it appears that the possibility is there (holes, screws, bolts etc symetrical either side of the door). But posts made by Samsung on forums suggest that only dryer doors are reversible due to fixed position of door lock on washing machines. I could try myself, but I'd have to remove the rubber seal to get to the back of the door lock. Don't want to go through all that if it's anyway a non starter!
SOURCE: Reversing the Door
nope only the dryer doors are reversable..last washer to have reverable door that i know of was old neptune
SOURCE: Whashing machine leaking
Hi my name is joyce
Yes you can fix this yourself but you really need to let a specialist do this so you know that it is done so it wont leak. it may costly at first but it will be worth it.
if you want to do it yourself go online and type in hiya.com and go to their website and type in your model # and get your ser# and then call your local dealer in your area that deals in washers of that sort and order part and go to work.. good luck..
thanks
let me know how it turns out and please remember to rate me
joyce
SOURCE: how do i change the door seal?
You'll have to find the screws that hold the door skins together. Take them out, replace the seal & reverse the order.
