Tv 2years old.After turn on power, TV work very good, but later{about 40 minutes ,some time an hour it turn off it self.we unplug power cordand connect again TV work well but it happen again and again...
Re: Power turn off after 45 minutes to 1 hour used
Check the "Sleep Timer" settings. If set to 45 minutes then TV would automatically turn itself off 45 minutes from being turned on. The variance in the "on" times is due to the TV turning itself off after not getting a signal from the remote for fifteen minutes.
Power supply regulator board problem. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. http://electronicshelponline.blogspot.com/
U have a small power surge somewhere.Disconnect all connections to the tv and unplug the tv and replug it back like about an hour later.Reconnected all connections.Go into the the tv Sound Setting to do a resetting of the sound setting back to the factory reset.The tv sound should work find now.If still have the same problems,then the main tv Tuner signal board it is shorted and have intermitten dying parts on the tv Tuner signal board.Only choice now is tries buy a refurbish tv Tuner signal board for the replcement.Tries websites like Shopjimmy.com,Ebay.com to buy LCD tvs refurbishes pcb boards.
When tv it shutting itself off by it own does the tv power LED light indication flashes?Tv turn on now,the tv power light indication,just flashes?Yes,than ur tv power supply board is the causes and the problems.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Its the power supply!!
well i migrated to this issue from having no sound and video with just the power button illuminated. I replaced the power supply with one from an online salvage store and it worked fine for about two hours and then it shut off, turned it back on and then twenty minutes later off again...repeat... need an electronics person to trouble shoot and trace which resistors and or capacitors are overloading. anyone??
