Video Game Consoles & Games Logo
g
garett cutting Posted on Nov 25, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Playstation3 problems Was fiddling with the settings now I have no picture but can still hear clicking after pressing buttons
Anthony Ward
Level 2:
Guru:
  • Expert 397 Answers
  • Posted on Nov 25, 2013
Anthony Ward
Expert
Level 2:
Guru:
Answers
397
Questions
0
Helped
216692
Points
748
Probably changed the display settings. Turn off the Playstation 3 and the hold the power button for about 5 seconds, until you hear a second set of beeps. It sounds like you have changed your display settings either to HDMI but are not connected with HDMI or you have set the progressive scan and it's not supported by your TV. The above procedure will reset your display settings they auto detect your connection, provided you have kept up with the updates. Let me know if this doesn't work for you.
Was fiddling with settings now I have no picture but can still hear buttons being pressed
Use the power button on the front of the console, to put it in standby mode (red light on). Then press and hold the power button until you hear two beeps. This should reset your display output settings.
My unit turned off during gameplay now i cannot turn it back on even to eject the game
Follow the procedure below to fix the problem on your ps3,
1. Turn off Playstation®3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
Restart System: Restarts the PLAYSTATION®3 System.
Restore Default Settings: Reset all system settings back to default.
Restore File System: Checks for corrupt/missing system files.
Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
System Update: Update the PLAYSTATION3 System
My playstation3 has no picture!i tryed it with the hdmi and the rca and still no picture.it was just working earyer
Make sure the ps3 is off (red Light) and hold down the power button until you hear 2 beeps and release. There you go, hope that works
5helpful
I tried to connect my emerson 227 bluetooth to my ps3. it tells me to press the start button and enter button on the device at the same time and wait until the screen changes.. well it never changes.. what...
Pairing the Headset with a Sony Playstation3 Entertainment System:
To pair your [EM-227] Bluetooth Headset with the Sony Playstation3 (PS3), go to the PS3 main menu, scroll to "Settings" and select.
Scroll to "Accessory Settings" and select.
Scroll to "Manage Bluetooth Devices" and select.
The menu will ask: "The Bluetooth device has not been registered. Do you want to register it?"
Select YES.
Put your [EM-227] Bluetooth Headset into discover mode (see X.XX of this manual for instructions on how to get the headset into discover mode).
Select "Start Scanning" from the PS3 menu.
Once the PS3 has discovered the [EM-227] Headset the screen will read "Select the Bluetooth device to register".
Select [EM-227].
The PS3 will ask for a passkey. Enter [0000] then press "OK".
Now press O (the PS3 circle button) to get back to the previous menu.
Scroll to "Audio Device Settings".
Change the "Input Device" to [EM-227].
Note: "Input Device" is the microphone, how others will hear you speak.
By default, the "Output Device" will now switch to [EM-227].
Note: "Output Device" is the audio, how you will hear the PS3 audio and others speaking.
If you would like to hear the PS3 audio and others speaking through your TV or Audio System, scroll to "Output Device" and switch to "System Default Device". If you would like to hear sound through the [EM-227] headset, then leave the "Output Device" setting on [EM-227].
To test your connection, speak into the headset and you will see the bars above the "Microphone Level" moving. If not, repeat the pairing process.
Press "OK" to confirm the new settings. You are now ready to use the [EM-227] Bluetooth Headset with your PS3 Entertainment System.
For further assistance with Bluetooth settings on your PS3 please refer to your PS3 instruction manual.
Playstation3 will not connected to tv
Please try the following steps to cure your problem
Step 1. Turn the PS3 onto standby mode (red light on)
Step 2. Press and hold the power button. It will beep immediately when you press it and then beep again about 5 seconds later. When you hear the second beep let go of the power button.
Step 3. Wait for your PS3 to start up
This procedure resets the video to standard definition and should hopefully solve your problem
Hope this helps and thank you for using FixYa
3helpful
2answers
Playstation3
Becoz ur hard disc got corrupted ! But don't worry, U need swith on the PS3 & touch hold both the "Eject" & "Power/Reset" button for 20 secs or until a triple beep sound. It will restart the PS3 with a Message " Press X Button to restore the corrupted data ".. Enjoy.. !! =D
2answers
Cant hear
go to your settings and make sure that the microphone is set to headset.
4helpful
3answers
Error. Press shuter release button again
I was taking pictures, then when I pressed the shutter release button, it took a long time. Then the error message came up. I tried pressing the shutter release button again, nothing happens. Still the error message. Please help me
4helpful
2answers
Easycap
I had the same problem and found that if I went into the options and chnged the format from NTSC to PAL and then back to NTSC it would bring in my camera. Thanks to snrobby for the hint on the options idea.
1helpful
2answers
No picture
I'm sure you already checked the connections on both the ps3 and Tv to make sure they are firmly and properly connected.
So, when turning on the ps3, hold the power button for at least 6 seconds until you hear a second beep. this should reset your audio/video settings to normal.
if using HDMI, wait for about a minute for the ps3 and TV to negotiate a connection.
Top Video Game Consoles & Games Experts
MegaByteMe
MegaByteMe
Aron
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
