How to adjust bobbin tension
Be absolutely sure that the problem lies with the bobbin tension. 99.9% of tension problems lie in the "upper tension." If upper thread is creating a birdsnest under the fabric, the upper tension is too loose. If the bobbin tension is pulling to the top of the fabric, the upper tension is too tight.
One should adjust bobbin tension only when one is very familiar with a sewing machine. Before changing anything, be sure to mark the position of the bobbin tension adjustment screw first. That way, you will be able to return it to the original position if you need to. When making bobbin tension adjustments, move the bobbin screw only 1/8 of a turn at a time. Test before making any more adjustments. Repeat, test, repeat, test...
