Chrono/Alarm WR30M watch from Target. I lost the instructions. For some reason the alarm just randomly turned on, and I cannot turn off the option. I just have to set the time constantly so that it won't go off at the wrong moment. It's really annoying because I have to use this watch all of the time for track. Please help!
Here are the instructions to view, change alarm time and turn off alarm:
From normal time display:
Press MODE once to display stop watch. Press MODE again to change alarm time. Press MODE again to change time.
Press RESET once to display current alarm time. Press and holdRESET then press START to turn on and off alarm (watch for alarm symbol on top left) Press and holdRESET then press MODE to turn on daily alarm vs one time (watch day marker lines at the bottom)
Hope this helps.
Thanks! This watch has driven my husband crazy trying to turn off the alarm he never set! :-)Thanks! This watch has driven my husband crazy trying to turn off the alarm he never set! :-)
We provide a range of lone worker alarm and lone worker app, protection systems, provide expert safety training, and back it all up with BS8484 lone worker monitoring 24/7.
To remove the hourly alarm (or 'chime'), try this :-
Press and hold the RESET button and then press MODE. If you want hourly chime ON - all the days will be displayed, press MODE button again to switch OFF the chime - all the DAYS will disappear.
Mine is like those but brand shhors. I change time by holding reset. What concerned me is what are the digits displayed: first comes time, then comes the month and the day in small digits, and then comes 20 and two digits for year which is soon 23. After youre done reset finishes all.
TIME AND DATE
1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash.
2. Press ADJUST to set SECONDS to zero.
3. Press START/STOP to select MINUTES.
4. Press ADJUST to change.
5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM.
6. Press MODE when done.
7. To display DATE from Time display , press START/STOP.
8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE.
9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME
1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash.
2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM.
4. Press ADJUST to change.. Press MODE when done.
5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH
1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes.
2. With time displayed, press MODE to select Chrono Mode.
3. Press START/STOP to start.
4. Press ADJUST to view lap time. Press again to resume lap timing.
5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero.
6. Repeat for successive laps.
In time mode, hold set (bottom right button) to change date and time. The selected (flashing) item can be changed in one direction only using the up (top right) button. Press set again to cycle through each item until desired settings are chosen. In stop watch mode, the up button starts and stops the stopwatch, the set button will take a split time while the time is running. To reset the stopwatch, press set once while the time is stopped. In alarm mode, the up button turns the alarm on and off. There are three alarms available. To cycle though alarm times, press set. To set an alarm, press and hold set until the time flashes, then set the alarm time using the up button, cycle through hour and minutes using the set button. When finished, press set again. Timer mode. To set the timer time, press and hold set until the time flashes. The timer goes up to 23h:59m:00s. You cannot set seconds. Once set, the timer can be started and stopped using the up button. There is no reset for the timer, to start a new timer the time must be manual changed again. To check heart rate, press and hold mode until PUL is shown, place two fingers, one each on the top and bottom metal contacts for 6-10 seconds to get reading (This works best when not in motion).
I so have the same problem. I have the same velcrow chrono watch from Walmart. I was going to set the date on it when I accidentally set the hourly chime. I annoys everyone, especially when it goes off every hour.
If its the 4 button watch, you hold in the bottom right, which sets it to alarm, and then press the top right button. It bleeps at each press and turns on/off the alarm display.
TIME AND DATE 1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash. 2. Press ADJUST to set SECONDS to zero. 3. Press START/STOP to select MINUTES. 4. Press ADJUST to change. 5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM. 6. Press MODE when done. 7. To display DATE from Time display , press START/STOP. 8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE. 9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME 1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash. 2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM. 3. Press START/STOP to select MINUTES. 4. Press ADJUST to change.. Press MODE when done. 5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH 1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes. 2. With time displayed, press MODE to select Chrono Mode. 3. Press START/STOP to start. 4. Press ADJUST to view lap time. Press again to sesume lap timing. 5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero. 6. Repeat for successive laps.
how to turn off the alarm on my c9 target watch
