SOURCE: remote codes
Then you go by the UL listing code and search online to see what other manufacturers make it.
C-Dog
SOURCE: tv code
Kindly try this:
http://wiki.answers.com/Q/Code_for_sentry_universal_remote_for_soyo_tv
melnavz
SOURCE: bell express vu remote codes for soyo tv
1 - Hold the clear tv buttom until all 4 light flash red
2- Press the red tv buttom
3- Press the amount of time needed on the up cursor ( around select buttom) until your tv shut down
4-When the tv goes off press the search buttom ( at the end on the right side )
5-Press record
Then u can use the red tv buttom to control ur tv and u can control the volume on satelitte mode without going back to tv mode , if u press too much time while searching the code and the tv wont light back , do the same thing but instead pressing the up cursor press the down one to go back on the code it will be faster .
SOURCE: lost remote and need code for new one. This is a SOYO tv.
My charter cable company gave me the following three codes for their universal multi unit remote: 10047, 00600, 00629, 00699. The first one was developed by having the remote search for the code and it worked with my unit (identical to yours). The other two were provided by the cable company. Hope this helps!
SOURCE: remote control
Be sure to check all your menu settings for the remote control function. Shake the remote a little bit if you hear some rattling inside then its broken. It could bee the IR eye that's has developed a problem with-in the remote or the tv itself. Try a universal remote to see if its the tv or the remote that's not responding.
i have a 32inch prive remote that dose not work how can i get one or find a code or the replacement remote
