Cordless phone is able to pair successfully. stays connected all day. the next day when i return home, bt does not connect automatically, and when i try to connect on my mobile phone, it is listed as paired, but will not connect. i have successfully unpaired, then restarted the process all over again to have the same problem the next day. Using a Galaxy S3 android. (4.2.2)
Did you try the "Device Discoverable in ___ secs?".In settings, Make device discoverable first then set the length of time. Android phone have this limited BT capability i think.
Testimonial: "Good idea. I have tried leaving my phone on permanent discoverable mode. The problem was not with discovering the Bluetooth connection. The problem was after a few hours the connection would not establish. After scouring the forums all night I learned this is not a problem with my android phone. it is indeed a problem with the Motorola L512BT. Check out the plethora of aweful reviews on amazon. A lot of people have had the same problem with this cordless phone with a variety of cell phones. http://www.amazon.com/Motorola-Cordless-Answering-Bluetooth-L512BT/product-reviews/B003EXRQHA/ref=cm_cr_dp_qt_hist_one?ie=UTF8&filterBy=addOneStar&showViewpoints=0 I am returning mine this afternoon. I will buy the more expensive Panasonic phone and see if it works better."
SOURCE: How to pair a Motorola D200 to a phone??
The D200 is intended to stream music or audio from the PC to Bluetooth devices such has mono headsets or stereo headphones. It does not interact with a cellular phone.
You can also do VoIP calls with D200 (plugged into a PC using Skype or a similar program) and a Bluetooth headset. I use this so I am not tied to my computer when I am using Skype for calls.
Bluetooth Headset
Pairing Instructions
1. When you turn on your Samsung Bluetooth
headset for the first time, it proceeds into pairing
mode immediately.
2. If you have paired the headset with other
Bluetooth devices, make sure that the headset
is off. Press and hold the Multi-Function button
until the blue indicator light stays solid blue after
blinking.
3. Set your Bluetooth phone to discover the headset
by following your phone's guide. Typically, the
steps involve going to a 'Setting', 'Connection',
or 'Bluetooth' menu on your phone and then
selecting the option to discover Bluetooth devices.
4. Your phone will find the Samsung headset and
ask if you want to pair with it. Confirm this by
pressing the Yes or OK key.
5. Enter a passkey or PIN, 0000 (4 zeros), then
press the Yes or OK key.
6. If pairing was successful, the indicator light will
flash in blue 10 times rapidly before going to
flashing every 3 seconds. If unsuccessful, the
light remains on, and you will need to re-attempt
pairing.
7. When you turn on your headset after pairing
with the phone, the headset is automatically
connected to the phone.
8. When you turn on your phone after pairing with
the headset, the phone is connected to the
headset by pressing the Multi-Function button.
