I properly installed the product and my computer downloaded the hardware, but when I attempt to connect to the internet using the WPS button, my computer crashes.
SOURCE: I cannot get connected to the internet.
If I understand you correctly you currently have a computer connected directly to your ADSL Internet connection and it can connect to the Internet. When you disconnect the computer, connect the DG834G router to the Internet connection and then connect the computer to the router you loose the Internet connection. It sounds like a ?simple? case of the router not being configured correctly. What I would suggest is to reset the router to its default configuration and follow the installation instructions again from the start. I?m not a big fan of the software configuration wizards that these home routers come with BUT they are the best way to easily configure the typical installation. To reset the router: in-between the 4 Ethernet LAN ports and the ADSL port there is a small reset button. Press and hold the reset button until the test LED turn on (about 10 seconds). Release the button and wait for the router to reboot. Let us know if this works or not. If you still have problems the more details and error messages you can supply the better.
SOURCE: computer and wireless router being connected but no internet
To reset the Modem all you have to do is to get a Paper Clip or any object that is like a paper clip then just turn your router to the place where the LAN cables are and just nearby you will see a small button that is abit hidden , so just press that and while pressing it for 5seconds, remove the power cable and plug it back while the clip is still being pressed in the reset button.
Remove that clip from there and you should be able to see that your power light on the router is blinking, wait till it get stable, then all you have to do is login with going to 192.168.1.1 then enter the default username and password which is either admin, admin, or root, password. or root, admin
Then just configure your router again and all shall be well.
THanks.
Hope this helped you.
SOURCE: Linksys WRT160 router doesn't work
Wi-Fi Protected Setup Button
If you have client devices, such as wireless adapters, that
support Wi-Fi Protected Setup, then you can
use Wi-Fi Protected Setup to automatically
configure wireless security for your wireless
network(s).
To use Wi-Fi Protected Setup, run the Setup
Wizard, or refer to the “Wireless > Basic Wireless
Settings” section of “Chapter 3: Advanced
Configuration".
Wi-Fi Protected Setup LED (Blue/Amber) It
lights up blue when wireless security is
enabled. The LED flashes blue for two
minutes during Wi-Fi Protected Setup.
The LED lights up amber if there is an error
during the Wi‑Fi Protected Setup process. Make
sure the client device supports Wi‑Fi Protected
Setup. Wait until the LED is off, and then try again.
The LED flashes amber when a Wi‑Fi Protected
Setup session is active, and a second session
begins. The Router supports one session at a
time. Wait until the LED is off before starting the
next Wi-Fi Protected Setup session.
SOURCE: I'm trying to connect my
Click Start, All Programs, HP, HP Deskjet, Connect a new printer. Choose Network Printer, then connect the USB. It will transfer the wireless settings. Unplug USB. Viola! Wireless works.
SOURCE: Does the linksys-G support WPS or AOSS?
Good question, I have the same router & Brother HL-2280DW and ran the printer setup CD from Windows XP SP3 via temporary USB connection & it seemed to work. The WAN report on the printer itself says OK, however the computer can't seem to find the printer "No devices could be found on the network." I let setup make changes to Windows Firewall, not sure about Microsoft Security Essentials however. This seems like a nice printer/copier at a nice price but this setup is frustrating! PS If it's a security issue I'd like to say thanks to all the hackers for ruining technology for everyone, your junk is responsible for slowing down & complicating computers & technology in the world. Someone please do everyone a favor & start making antibodies that *kill* viruses & spyware & spam and clean & speed things up for a change! All these villians - Where are the cyber super heroes????
