I have a SportArt 6150 treadmill and I am having problems with the incline function. The treadmill works very great except that the treadmill's incline function does not work. When the treadmill is own and I press the incline up button (max of 15% incline) I hear the motor for the incline function working but the treadmill is not inclining. Any help would be great. Thanks for the response!
Debris.
My treadmill ripped the steel apart and the motor was pulling broken pieces of steel instead of raising. With the unit unplugged, turn it over. Physically inspect the shafts, gears, brackets for breakage, worn or stripped threads, missing hardware. Physical damage is more than likely your culprit.
SOURCE: My Proform treadmill will not incline. It is stuck
Under the hood there should be a tech sheet with calibration instructions. I have not worked on these for several years or I would rattle off the procedure. If the sheet is still there make sure you put it back in the plastic sleeve for next time..... Eric
SOURCE: I have a proform j8li treadmill, all 4 led lights
I have the exact same problem with the very same treadmill that i bouth 10 years ago and it has been sitting for 5 years unused. The last time it was turned on it worked but now that I plug it in and try to start it, everything works but the belt drive motor. Any ideas?
SOURCE: Image 10.0 treadmill incline not working
I have a image 10.0 treadmill. I recently started running on it about 2 weeks now, my problem is that now when i put the red plastic card in the console to start it up, the console completely lights up and starts to buzz, and i won't start. I've unplugged it, it worked, then when i shut it off again and reinsert the red plastic card it does the same thing. What is this problemand what can i do?
SOURCE: Treadmill incline error
Try this, it fixed it for me, if it doesn't work let me know
http://www.youtube.com/watch?v=MIIxoPtvhy8
I bought a used Precor 9.4 treadmill, but the incline adjustment was not working.
So, I did the following.
1. Turn off, unplug the treadmill and wait for an hour (this is for safety
2. Remove the black motor cover
3. Observe the transformer to the right of the motor and towards the belt ( I point to it in the video)
This transformer converts DC electricity to AC electricity and the AC current goes directly to the Incline motor which is in the black box towards the front of the machine.
4. On mine the wires had come loose from the transformer, they were soldered on very poorly, the wires are stiff and you should be able to see 4 wires coming from the top of the circuit board and plugging into the transformer, I had three of the 4 wires loose.
5. If you are not comfortable working with electronics or soldering DO NOT DO THIS REPAIR, you could get shocked very badly if you just go poking around in there with metal objects, get a friend who knows how to solder or hire someone.
6. It took about 5 minutes I just heated up my $10 soldering gun from radio shack and soldered all the loose wires that were about a millimeter away from the tabs on the back of the transformer, and VOILA! The incline now works!
SOURCE: Lifefitness TR 9000 treadmill - 1997 model
Because you are hearing the lift motor making a noise, it sounds like the gears in the motor are bad. The fix is to replace the lift motor.
Sounds like the gears in the motor are stripped - Sportsart sells them
