Hoover F5866-900 SteamVac Deluxe Wet/Dry Vacuum Logo
T
Tim Alger Posted on Nov 12, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No suction or brushes turning after auto shutoff
I am having a similiar problem as most but have not been able to solve the issue so far. The auto shutoff engaged...I emptied the tank and tried to continue but the brushes would not turn nor was there any suction. The motor is also louder as if the auto shutoff is still engaged or something is clogged. I replaced both the turbine and the waster container, cleaned the filter, brushes, etc...still nothing as changed. Am I missing something? Tim
  • Tim Alger
    Tim Alger Nov 12, 2013
    It is a Hoover Steam Vac Dual V F7412-900...not sure how the F5866 number was posted
sethlite
Level 2:
New Friend:
  • Expert 139 Answers
  • Posted on Nov 12, 2013
sethlite
Expert
Level 2:
New Friend:
Answers
139
Questions
0
Helped
27835
Points
269
Make sure that there are no clogs in any of the hoses. Also, check any belts. Make sure that they are in place and they are spinning.
Testimonial: "There are no hoses to clog or belts to check. The turbine that spins the brushes operates from suction. It seems like the auto shutoff with not reset."
5 Related Answers
Anonymous
  • 3614 Answers
  • Posted on Jun 01, 2008
SOURCE: Hoover SteamVac LS F5899-910
Did you try to clean first the unit..
Anonymous
  • 1673 Answers
  • Posted on Jul 27, 2008
SOURCE: Square hole will not turn on my Hoover F7210-900
You have to take the top cover off, turn unit over and from the bottom, remove the screws, 2 of them will be long, they hold the turbine down. Turn it back over and removethe cover. There 2 more screws at the front of the turbine (#23 and the hoses attached to it. Then it will come off.
Anonymous
  • Posted on Dec 06, 2008
SOURCE: Brushes not turning, but suction okay?
My problem was that the metal "transmission" had it's upper and lower bearings frozen. I sprayed WD-40 and let it sit for awhile. I then proceeded to work it free. It was quite rusty inside the cover plate, leading me to believe that water somehow entered the housing or they used a water based lubricant from the factory. Water based lubricants are generally cheaper than oil based so I'm tending to lead that way. The "transmission" is the metal rod with hypoid type gear in it that turns the 2 plastic gears. It is a press fit to the turbine wheel, so twisting a flat blade screwdriver under the turbine wheel will remove it. Make sure the lower bearing is free to turn easily. I also used some anti-sieze compound on the gears.
Robert Pagliaroli
  • 294 Answers
  • Posted on Oct 28, 2009
SOURCE: No Suction
The water channel hose could be torn. you can check by removing the lower tank and tilting it backwards, it is located in the lower section. could also be the filter cover. it is needed for full suction control.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Anonymous
  • Posted on Nov 05, 2009
SOURCE: brushes still wont turn
I took the tubine apart ,one gear was stripped.Can I get 1 gear? all so on small bearing.
1helpful
Its not turning brushes all the time & it has very little to no suction on floor or hand tool modes
HI, it's Jim from Crucial Vacuum!
If your vacuum is experiencing difficulties with suction there are several places you can check to help your vacuum operate at its peak performance. After applying these solutions you should see an improvement in your vacuums suction and the maneuverability of the brush roll.
Lets check out your brush roll first since that's experiencing issues with turning. Look for any noticeable debris, and be sure to manually rotate the brush roll to unearth any hidden clogs that may be behind your brush roll. If you see carpet fibers, or strands of hair remove these with a razor, or scissor.
How do the bristles look on the brush roll? If they're loose, or look worn down then it may be time to replace the brush entirely.
Is the belt intact? After usage the belt will stretch out and lessen the tension on the brush roll. This could be causing the brush roll to have a lack of resistance against it. You want to be sure the belt is on there nice and tight. If your brush roll isn't operating properly it won't be able to pick up dirt and debris.
Be sure to empty your unit's dust cup. Allowing for fine dust and debris to rest in your unit's dust cup for a long period may cause your unit to become clogged, which leads to poor or even no suction for your vacuum.
If you're also getting little to no suction from your vacuums hose and attachments then check your vacuums hose for a clog. Stretch it out as far as you can to unblock any clogs. If there is a clog in a hard to reach spot try using a broom handle to reach the area.
It is recommended to wash and clean your unit's filter weekly. To do so, empty your filter screen outdoors to take off any excess debris and then clean under running water until the water comes out clean. Allow the filter screen to fully dry before inserting it back into the unit. This may take up to several hours.
You can purchase replacement parts for your vacuum direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim Thompson
Crucial Vacuum Customer Care
Mar 01, 2015 • Vacuums
Beater bar not working. suction not working
Check for a broken beater brush belt. Clean the beater brush, clear of all debris and add some WD40 at each end where the rubber holders are. Turn beater brush by hand to work the WD40 into the axle. Reassemble making sure the belt is on correctly. This should also help solve the suction problem as well.
No suction in hose
Remove the machine side of the hose--is there suction at the machine? If so, run a broom handle or similar through the hose to dislodge the clog. If no suction at the machine, you may need to fish out debris with a hooked stiff wire from the port. Remove the bag and examine the port area underneath for similar clogging. Finally, check the brush area underneath the machine bottom plate for more obstruction. Also, check the brush assembly for debris accumulation. Remove the drive belt and check for free turning of the brush. If turns hard, remove the brush, clean the bearings and roller pins, then apply a small quantity of light oil like 3-1 or sewing machine oil. Hope this helps!
2answers
My dyson vacuum motor is sounding very high pitched... The tubes are all clear and there is suction with the tubes not not real good suction on the beater brush area....
Your dirt path is clogged, probably not far from the brush area. This is the reason you noticed the hi-pitch sound coming from the motor.
You may have to remove the hose to clear it.
Jan 19, 2010 • Vacuums
Have suction, new bag, brush moving but does not
Solved!!!
I went to my local Sears store and the salesman there looked at my vacuum and was able to resolve the issue. There was a piece of wire that had been sucked into the machine that then blocked anything else from being vacuumed up.
Thanks for your help.
2helpful
My dyson DC07 has no suction. motor runs, brush spins, just no suction.
hi..the reason to this problem may be the bottom pieces
might not have been fully seated.Take it apart and put it
carefully back together.This will solve the issue.
check it out..
thank u..
kindly rate my response..
1helpful
Hoover Steam Vac - Brushes not turned, no suction power
The Brushes not spinning is most likely is caused by seized bearings in the turbine, requiring shop service (easy fix). The suction issue can be caused by the standpipe seal missing or lower recovery tank not on properly, on some models missing front panel. I would need more exact model info to assist further.
3helpful
2answers
Bissell lift off pet-no suction through base (hose is fine)
I had a similar problem with mine. When you take the collector container out, if you reach your hand up, you will fill a round, plastic piece. Gently turn it and the piece pulls out. On the outside of the piece is a foam filter that may be plugged. There is another filter underneath the collection container in a pull-out drawer. Both filters can be washed with cool water, allowed to dry totally, then replaced. I understand that both of these filters need to be washed "frequently". It worked for me, hope it works for you.
Top Hoover Vacuums Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
