SOURCE: "CH 01" shows on the display screen
This will need to be serviced. LG has a 5 year warranty on these models. They usually will tell you of a service center nearby which will service it free of charge since it is under warranty. If you do not live near a service center they may ship you a replacement and you send your old dehumidifier back to them. Make sure you have your reciept when you contact them so they can verify it is under 5 years old.
SOURCE: Dehumidifier Error?
Same problem with Goldstar model DH404EY7 -- stop code 01 on startup, bucket full light blinks (drains to floor).
Replaced the main controller board to fix it.
For my model dehumidifer the part # is 6871A20888A, and cost $77.44 (not counting shipping) from Appliance Factory Parts. The Appliance Factory Parts web site also provides parts breakdown (exploded parts diagram) diagrams and service manuals in PDF form.
SOURCE: I turn on the dehumidifier and the red indicator
Here is a tip that explains what can be happening to make the dehumidifier show that the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
SOURCE: Hi, When I tried to
Your model is no longer in manufacture or available. However, I was able to locate the Owners Manual for you. It does not list a CH 01 Error Code, but does list other reasons why your unit want turn ON.
http://www.lg.com/us/support/product/support-product-profile.jsp?customerModelCode=LHD45EL&matchedModelCode=1000001989&searchEngineModelCode=LHD45EL&targetPage=support-product-profile&initialTab=documents#
In the past, I have recommended turning the Master ON/OFF Switch to OFF and unplugging the unit for 12-15 minutes. This will give the unit time to hopefully, reset itself. Then Plug the unit back in and turn the Master ON/OFF Switch to ON. Set the humidity control as you normally would. If it successfully reset itself, it should operate normally.
If you continue to have problems, contact LG Customer Support at 800-243-0000.
Hope this helped you to solve the problem.
SOURCE: Have n lhd659ebl dehumidifier. Worked for 10
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
heatman101
