Did it get hot and make a noise and quit? If so you have just burned it up. The gas mixture was not correct and or the crab adjustment were not adjusted correctly to cause this. If this is the case you will need to replace the barrel and piston as a pair. Quite expensive. If you have done this and need to have a shop do it, the cost is more than a new saw. If you do it yourself you are still looking at $150.
