Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
When your locks are going silly, 1 of your doors will be responding differently, that is the problem part, your activation switch is broken on your door lock, if you can manually move this lock to the opposite possition should temporally solve the problem untill you want to lock the car again
open the r.control and clean the keypads from dirty, oxide, corrosion with contacts cleaner, tight the spring contacts batteries and clean it and try again.
The turn signal is on an intermittent switch. The relay or fuse under the hood might be bad. If you can't find the one inside, look for a cover that says FUSE BOX on it. If no luck, refer to your owners manual.
