I am wondering if the wiring harnesss I have on my alpine now would fit the Pioneer stereo? I am unable to get another wiring harness because the previous owner cut the factory ones
Hi
It is no problem for replace your alpine stereo and you can get read review Pioneer AVIC-Z140BH .
It has Touchscreen In-Dash, Navigation AV Receiver, iPod,Sat radio,Bluetooth
Read more review or check from Amazon.com
SOURCE: Alpine CDE 7853 removal
remove the face and then the trim ring for face you should see 2 little pins on either side of the radio slide them up and it should slide right out
SOURCE: alpine
YOU MAY BE ABLE TO GET A HARNESSADAPTOR. IF NOT GET AN "ISO" PLUG FROM YOUR FACTORS, AND FOLLOW THE INSTRUCTIONS ON THE PACK, 1 PLUG IS THE POWER PLUG SO FIND THE SWITCHED LIVE, CONSTENT LIVE AND GROUND FROM CAR SOCKET. THE YELLOW IS CONSENT/MEMORY RED SWITCHED, BLACK GROUND EARTH, THE SPEAKER LEADS ARE PAIRED BY COLOUR YOU CAN TEST THESE WTH A 9V BATTERY TO FIND WHICH ONE IS WHAT, THE SPEAKER WILL BUZZ
SOURCE: alpine 9845 cde head unit car stereo
Press the Rotary encoder (CDE-9845/CDE-9843
only) or press MODE (CDE-9841 only) repeatedly
to choose the desired mode.
Each press changes the modes as follows:
BASS → TREBLE → SUBWOOFER* → BALANCE → FADER
→ DEFEAT → VOLUME → BASS
BASS: -7 ~ +10
TREBLE: -7 ~ +7
Subwoofer : 0 ~ +15
Balance : L15 ~ R15
Fader : R15 ~ F15
Defeat : ON/OFF
Volume : 0 ~ 35
SOURCE: need wiring diagram for pioneer deh p3900mp
here is the link to your manuals:
http://www.pioneerelectronics.com/PUSA/Support/CarAudioVideo/In-Dash/CD-Players/ci.DEH-P3900MP.Support
see pg 2 of other manual for wiring diagram
Cheers!
Setting Time
1 In the Clock priority mode, press and hold
TITLE for at least 2 seconds while the time is
displayed.
The time indication will blink.
2 Turn the Rotary encoder (CDE-9845/CDE-9843
only) or press 4 and 3 (CDE-9841 only) to adjust
the hours while the time indication is blinking.
3 When the hour has been adjusted, press the
Rotary encoder (CDE-9845/CDE-9843 only) or
press MODE (CDE-9841 only).
4 Turn the Rotary encoder (CDE-9845/CDE-9843
the minutes while the time indication is blinking.
The time is automatically set 5 seconds after the minute
adjustment. The time can also be manually set by
pressing the Rotary encoder (CDE-9845/CDE-9843 only)
or press MODE (CDE-9841 only).
ā¢ To synchronize the clock to another clock/watch or radio time
announcement, press and hold the Rotary encoder (CDE-9845/
CDE-9843 only) or press and hold MODE (CDE-9841 only) for at
least 2 seconds after setting the "hour." Minutes will reset to 00. If
the display shows over "30" minutes when you do this, the time
will advance one hour.
Or you can ge tthe manual on the link below.
http://a248.e.akamai.net/pix.crutchfield.com/Manuals/500/500CDE9843.PDF
