SOURCE: System Error
Defective mechanism, a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. You need professional service to fix it.
SOURCE: system error 10
You can try taking out and replacing the memory card with the original that came with it. You can also take out the batteries for a while and then put them back in. That's what Nikon suggests. If this doesn't work you are told to call Nikon.
Let me give you a little information about this issue. Nikon 4600, S1 and S3 have a faulty operating system. The good news is that there is an update for it. The process of repairing that issue might take an hour or two. You have to hard boot the camera with a jumper setting on the unit to force the new operating system in the camera and then upload all the updates.
Nikon is repairing them for people, but they want you to send it in and are charging people $87 for the repair. You might be able to find someone near you that can do the repair for you much cheaper.
It might just be better to buy a new camera.
Sorry i couldn't help more. Good luck.
SOURCE: system error showing up on Nikon coolpix 3200
A System Error is a general error which can be caused by many things: lens problem, CF Card problem, general camera failure, etc. Before sending the camera in, check these:
1. Use the memory card that originally came with the camera (or a Nikon approved card)
2. Remove and replace the battery
If the error is still displayed, contact Nikon's Service Department (below). If the above tips do not help the camera must be sent to Nikon Service, there are no user serviceable parts on Nikon Coolpix cameras.
SOURCE: Nikon Coolpix L3 51 megapixels lense error
You may not be able to... but may be worth a try.
See my posts on this problem.
