20 Most Recent Nikon Coolpix 4600 Digital Camera Questions & Answers
0answers
Nikon Coolpix 4600. Lense
Any sand in a compact camera is bad news - repair will be expensive. In your situation, I would continue to use the camera while it still works, and give serious thought to a replacement.
7/20/2017 11:31:09 PM • Nikon Coolpix... • Answered on Jul 20, 2017
Screen black.
Hello, I went and researched a few points in the manual and hope this helps to some extent. If this doesn't help, try resetting your camera by removing the batteries for 30 seconds, then reinstalling them and turning on the camera again.
Monitor is blank:
• Camera is off.
• Batteries are not correctly inserted or battery-chamber
cover is not properly latched.
• Batteries are exhausted.
• EH-62B AC adapter (available separately) is not properly
connected.
• Camera is in sleep mode. Press shutter-release button
halfway.
• Monitor is off.
• USB cable is connected.
• AV/Video cable is connected
No picture is taken when shutter release button is pressed:
• Camera is in playback mode.
• Red (!) lamp flickers: flash is charging.
• Green (AF) lamp flickers: camera unable to focus.
• Message "CARD IS NOT FORMATTED" appears in
monitor: memory card is not formatted for use in your
camera.
• Message "OUT OF MEMORY" appears in monitor:
insufficient memory to record picture at current Image
mode setting.
3/20/2017 5:16:25 PM • Nikon Coolpix... • Answered on Mar 20, 2017
2answers
My Nikon Coolpix 4600 refuses to take photo
Ask it nicely this time.
6/3/2016 8:46:29 PM • Nikon Coolpix... • Answered on Jun 03, 2016
2answers
Camera frozen
Same problem here! >_>
I wanted to check my pictures, and it completely frozen, so i took the memory card out but it still is frozen, with the lens out!
help! please!
4/23/2016 9:10:23 AM • Nikon Coolpix... • Answered on Apr 23, 2016
Nikon coolpix 4600: How to transfer pictures from camera to card?
ok I figured out how to do it! put the memory card into the camera, then go to view the pictures. Then press the menu button and scroll until you see the copy button. Then you will see the option to copy from camera to card, or card to camera. Press the option to copy from camera to card and press select all....(or whichever pictures you want copied...I wanted all pictures copied). Then voila! it takes a few seconds to copy from the camera to the card, and there you have it! :)
1/4/2015 2:24:20 PM • Nikon Coolpix... • Answered on Jan 04, 2015
Why my nikon coolpix 4600 do not turn on
Always be sure the batteries are charged and suited for your device. Check contacts of the batteries and in the battery compartment of your device. Dirty or oxidised contacts can be cleaned with a dry cloth, or a cotton swap. Never use sharp tools to clean contacts or anything sharp in or on electronic equipment. Always charge batteries before using it for the first time, or if you have not used it for a long period. 3 months is a very long period. Also check if the battery door is closed correct. there is a switch connected to the battery door. If the switch does not work correct, it could be you can't switch on your camera.
9/6/2014 1:06:18 PM • Nikon Coolpix... • Answered on Sep 06, 2014
Memory card locked
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
9/2/2014 7:25:50 PM • Nikon Coolpix... • Answered on Sep 02, 2014
0answers
Will a 8 GB SDHC replace a 512 MB in a Nikon cool pix e 4600?
No. The 4600 works with SD cards, 2GB or smaller. It does not work with SDHC cards.
5/25/2014 3:32:07 PM • Nikon Coolpix... • Answered on May 25, 2014
Will 4600 handle 8gb sdhc
No. The 4600 works with SD cards, which max out at 2GB.
5/25/2014 3:31:49 PM • Nikon Coolpix... • Answered on May 25, 2014
P100 was working took 1 picture and froze open. white screen won't charge
Perhaps you have an empty battery? Just remove the battery and try charging it on an external charger. When it is charged, try again. The camera should start with retracting the lens. Perhaps you again should power down and remove the battery for a few seconds after that, but just try it. Switching of a camera causes it to start again, like a cold boot from a computer. Monitor your battery, because if the camera shuts down very soon after that, perhaps you need a new battery?
5/8/2014 2:07:47 PM • Nikon Coolpix... • Answered on May 08, 2014
0answers
2answers
Lost Pictures
I'd recommend that you follow this digital camera photo recovery guide as soon as possible to recover those pictures.
5/7/2013 5:32:38 AM • Nikon Coolpix... • Answered on May 07, 2013
How do i turn off the flash on the nikon coolpix 4600
Press cursor-up (marked with a lightning bolt) to bring up the flash menu, select the lightning bolt in a circle with a slash through it to turn off the flash, and press the OK button in the middle of the cursor pad.For full details see the "When Lighting is Poor: Using the Flash" section of the manual (begins on page 24 in my copy). If you need a manual you may download a copy here.
1/28/2013 12:43:13 AM • Nikon Coolpix... • Answered on Jan 28, 2013
SanDisk 16Gb SDHC will it work with nikon 4600
No. The 4600 works with SD cards, which max out at 2GB. It will not work with higher-capacity SDHC cards.
1/13/2013 4:36:49 PM • Nikon Coolpix... • Answered on Jan 13, 2013
Nikon Coolpix 4600 Digital Camera Logo
240 questions posted
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
View Most Popular
COOLPIX Nikon
  • COOLPIX Nikon
Most Popular Question
lost pictures
  • Cameras
