SOURCE: Toshiba laptop won t start up
try taking the hard drive out then switch it on without it then switch it back off, put the hard drive back in then it should work, if not try f8 then safe mode and do a system restore
SOURCE: starting up problem
I had the same thing. I was passed down this laptop to checkout for a friend. After overviewing the system turns out the processer board got loose. Pushed it back in and she fired up..
Issue was green power led then 2 short orange flashes that repeated untill I discoved the issue.
SOURCE: when i start-up my toshiba satellite m100 it ask to insert media
try to remove the media player form the.. system, sturt up..
Go to start, run, type msconfig then enter, then remove sturt up then ok
SOURCE: Toshiba satellite A70-KL1 notebook shuts down
Boot off your windows installation disc and choose repair, windows will attempt to repair the startup if problems are discovered. When the repair is finished reboot normally.
