F3 on a GE / Hotpoint microwave means you have a shorted membrane keypad.
Part number WB07X10959 this part can run over 100 bucks. If you shop around you could get a good price.
Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
SOURCE: GE Microwave JVM3660SD001 Control Panel Removal Procedure
Remove the grill, should be screws on the top of the unit. There should be one screw behind the grill at the top of the control panel. Remove it and pop the control panel up to remove it. Make sure the mw is unplugged first. Then you can remove the board.
SOURCE: ge spacemaker xl1800 microwave
F3 on a GE microwave indicates a defective keypad.
The keypad is a thin plastic membrane type that is glued to the plastic control panel frame.
If none or only some of the pads are working, there may be some foreign substance on the circuit board, the keypad connection, or inside the layers of the keypad, the latter of which cannot be repaired.
Trouble is sometimes due to spray cleaner being sprayed directly onto the keypad. Cleaner should be sprayed on the cloth first, then use the cloth to wipe the keypad clean.
Never use an ammonia-based cleaner on plastic as the ammonia can attack and crack it.
A handy person can remove the control panel frame and see if there's any liquid inside on or behind the panel. If so, it is possible to dry it out, but often that does not work.
Another thing is to unlpug the power at the mains for several seconds. Plug it back in and see if it works. A reset may do it.
At power-up, the display should flash or show a text message. If not, a key may be stuck due to a foreign substance or a defective keypad.
If certain keys are not working, there may be some foreign substance at the point where the green or blue plastic strip from the keypad plugs into the circuit board.
To check that, see our critical safety, disassembly, and troubleshooting info at our site. You'll find a link to our site in our
listing here on FixYa: http://tinyurl.com/yzjozk
1. Be sure the oven is disconnected from the power line while you are taking it apart.
2. The keypad connection is the green or blue translucent plastic strip that plugs into a connector near the edge of the board.
3. There are two tiny tabs (one on each side) of the connector that you can gently pull up on to unlock the connector.
4. Then the keypad strip will lift out. Clean both sides of the end of the strip with a pencil eraser or alcohol-based cleaner if you like, but do not use ammonia-based cleaner. Dry the end of the strip.
5. Put the keypad strip back in, making sure both sides are down fully.
6. While holding the strip down, push the connector back down to lock it.
7. Try the keys again with the door closed.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: microwave malfunction
On a GE microwave F3 means you have a failed keypad.
We replace these for customers nationwide with our guaranteed $39.95 service.
If you might want to replace it yourself, I have uploaded a handy guide
with pictures showing you what's typically involved. It's here.
Please feel free to contact me directly if you need more help.
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
SOURCE: GE SPACEMAKER XL MICROWAVE OVEN JVM1440
Assuming that your internal cooling fan is working, I would suspect that your magnetron is failing.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There
should also be a "mini-manual" hidden inside the unit behind the
control panel or hidden on the
left side behind the grille, which is
very helpful when troubleshooting, testing, and locating components.
I would check the cooling fan, then suspect the magnetron.
SOURCE: microwave ge spacesaver touchpad does not work except for the
You have a failed
membrane keypad.
If you (or someone you
know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically
involved.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
There
should be a "mini-manual" (tech sheet) hidden inside the unit
behind the
control panel or hidden on the left side behind the grille, which is
components.
If you would like to
have us
do this repair for you, we do that for $39.95 plus part costs nationwide.
But please note that for
some GE models, the membrane keypad is not
available as a separate part, so you would have to order the control
panel frame assembly which comes with a new keypad.
In this case, you simply
move your circuit board into the new frame. That is a simple do-it-yourself
job.
Either way, we can let
you know what your options and costs would be and send you other
helpful info.
At
our Web site, we have a video
available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
Feel free to contact me directly (and please remind me of your
full model number from the tag on the unit) for more
information & help.
We're
[email protected]
Microwave Oven Control Panel Repair Nationwide
Testimonial: "Thank you for your detailed response. Nice to know you are there for support."
Hi
F3 error in your GE microwave
means that the keypad/touchpad is bad and should be replaced. However, before
replacing it you can follow these step by step instructions to clean the
touchpad assembly and see if it works:
1) Unplug microwave
2) Remove two small screws from upper face plate
3) Remove screw on upper side of control panel
4) Life panel and pull out
5) Identify flat tape-like harness connecting
circuit card to keypad
6) Wipe down harness with an all-purpose wipe
7) Use hairdryer to dry remaining leftover
moisture
8) After this put the keypad back
if its not solved then replace it.
Hope this helps...please post back
for further assistance.
Daniel
