Nikon D40x Digital Camera Logo
Corin Morgan Posted on Oct 25, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sd card won click memory - Nikon D40x Digital Camera
Art Scott
Level 2:
Novelist:
  • Nikon Expert 357 Answers
  • Posted on Oct 25, 2013
Art Scott
Nikon Expert
Level 2:
Novelist:
Answers
357
Questions
0
Helped
68921
Points
473
Do you mean that the SD card does not lock in place? If so the SD card hold is defective and will have to be replaced.
Do you mean the camera won't click (fire?). That is usually caused by a failure of the motor for the SQ unit on the side of the mirror box
2 Related Answers
stormwind13
  • 77 Answers
  • Posted on Nov 01, 2009
SOURCE: my d90 will not accecept the memory card
the spring loaded receiver is probably broken, take it in to a camera repair store and cross your fingers.
Anonymous
  • 13 Answers
  • Posted on Nov 08, 2011
SOURCE: Nikon d40xcamera...sd card won't click into slot
there is a lock on the side of some sd cards try checking if there is one.
Won t recognize sd card
It seems that the card reader if the computer is not detecting the card. Make sure that the memory card you use is supported.
The multi-in-one card reader on the Aspire One can read and write to Secure Digital card (SD), Secure Digital High Capacity card (SDHC), MultiMediaCard (MMC), Memory Stick (MS), Memory Stick PRO (MS PRO), and xD-Picture Card (xD). Specific models of the Aspire One are also equipped with an SD Expansion slot that can read and write to Secure Digital (SD) and Secure Digital High Capacity card (SDHC) cards.
The multi-in-one card reader on the Aspire One can read and write to miniSD, microSD, Memory Stick Duo,and Memory Stick PRO Duo cards but require the use an adapter. Acer does not provide or support any memory card adapters.
You can try removing the card reader using the device manager and the reinstall it and check the operation. You may also try using the card is different computer and check. Also try using another card in the computer with the issue and check. If the issue is not resolved please revert back with the model number.
Click on the link for the information to Reinstall a Device
http://technet.microsoft.com/en-us/library/cc725782.aspx
2helpful
2answers
Why won't my Sansa 250R won't recognize an sd card?
Your 4GB card is actually a microSDHC card. The e250 works with microSD cards, 2GB and smaller.
1helpful
My memory card for my d3100 won't format, I've
Dear Madeline Birch,
I suggest, you use the laptop to format your card. The process is as follows.
- Insert the SD card in the SD Card slot available on your laptop. Enter My Computer, and right click on the icon which represents your card. Format it from there as you would do for any other USB data storage.
If you don't have a laptop, or your laptop doesn't have the SD Card slot. Then, you should purchase an SD Card reader. The process mentioned above would be similar.
If all fails. I recommend you to get another card, as the card may have been corrupted.
Hope I was able to sovle your problem.
Regards,
Rebel K
Jan 13, 2013 • Cameras
1helpful
Forgot my memory card pasword
To format your SD card you need the following SD card, SD memory card adapter, SD card reader on your P.C. first insert the memory card into card adapter, insert the adapter into the P.C, click start>my computer> Secure Digital (SD) card and then navigate into the folder named system folder, open the sub-folder MMCstore and you should be able to see your password and recover it, If you want to reset your password you should just format SD card by clicking start> right click on my computer and select manage> Disk management > go to your SD card, right click on it and select format and then start format.
Sony 1GB Memory Stick PRO Duo Memory Card "full"
You can try recovery tool to see whether your memory card corrupted or not. For example, 4Card Recovery, which is able to recover various files in a few minutes.
Step one, download 4Card Recovery online and install it on your computer.
Step two, run it and choose the files that you want to recover, of course, you can choose recover all files in case of the omission of anything.
Step three, scan it by clicking the 'next' button and wait for about ten minutes.
Step four, save the recovered files on other part to avoid losing it again.
Hope you can solve the problem with this. Have a try.
How to Recover Photos Videos off SD Card after Formatting Unformat SD...
Camera won't register that there is a memory card, always saving pics to internal memory
Did you use a high capacity memory card with an old camera? For example, did you use a SDHC card in a somewhat old camera?
Some cameras accept only SD card. Although SDHC card has the same shape, it won't be reconized by the camera.
Sep 23, 2011 • Cameras
I can not get our memory card to format. it says card error. we are using a microSDHC Ccard with adapter 4gb
Is the camera compatible with SDHC? If it can only handle SD memory cards this card is not readable in the device. It will show on the camera whether it is compatible with SDHC. If it doesn't have the logo, take it as the card won't work and you'll need to get a normal SD card.
There is a theoretical maximum of 2GB for SD memory cards, SDHC start at 4GB and go up to 32GB.
Simply put, if your camera is quite old, it won't support SDHC and therefore is limited to a maximum of 2GB memory card.
Jul 26, 2011 • Cameras
My SD card won't stay in camera
Fix 4 http://camerarepair.blogspot.com/2009/07/simple-fix-for-memory-card-locked-error.html?m=1
1helpful
W what size SD memory card can i use?can i use
You may use any SD card up to 2GB in size. Make sure you don't try larger SDHC cards, as they won't work.
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
