Need list of codes for game changer remote for an Orion tv
072,077,079. Check these codes. If
you wish to get more details, check the sites linked here. Setup code list, and setup procedure to many
popular brand remote controls are given.
http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/ Selecting the view option, either to Mosaic
/ Time slide, can be selected by the drop-down list, at the top left
of the display window, will make surf easy.
SOURCE: remote codes
Check out this website...
http://remotefinder.rca.com/default.aspx?site=rca
You will need to check the model number typed in the battery cover of your remote to be sure.
SOURCE: Insignia TV code for RCA Universial Remote Control (RCR450)
If its a four digit code remote. I may be able to help.. Try these...0171, 1204, 1326, 1517, 1963, 2002..
Good luck
SOURCE: i cant find the code for my one for al remote for my orion tv
Try this:
Turn on the device you wish to program
Press and hold CODE SEARCH until the indicator light lights,then release CODE SEARCH
Press and release the device you are programming(TV,VCR or cable).the indicator light will blink once then remain lit
Press and release OFF/ON until your device turns off(you may have to press off/on up to 200 times)
When your device turns of,press the ENTER button the indicator light will go off.Your code are saved
Visit the site named 'Electro-help' for more
details. Click this link. View it in
"Timeslide" or "Flipcard" option, which can be selected
from the drop down box menu by the [Sidebar] tag, at the top left corner
of the display window. You can also
click the [Home] tab to the latest updates. It will make search easy.
There are more than 1300 posts to different brand TVs now. Pull up older posts
there.
