<1>. Press and hold on Esc key, and then start Samsung laptop
Note: Please don't loosen your hand on Esc key until the Samsung laptop starts with restore system.
<2>. Find Samsung Recovery Solution program, and run it. Or Enter Menu window.
Note: Samsung Recovery Solution is system restore program provided by Samsung. Used for Samsung password recovery etc.
<3>. Press F11 to restore Samsung factory setting.
Method two:. Just start your Samsung laptop and press F4 or F7 at the same time. And Samsung laptop will run system restore program automatically. When the program runs over and reboot Samsung laptop, you can access Samsung laptop without any password
shorter , RTM
read the manual recovery chapter
do it. do as it tells you, or buy a newer OS
THE ANSWER IS RTM.
READ THE MANUAL AND THEN ASK QUESTIONS NOT CLEAR.
if the discs were lost?
and the imagine F4 is dead, now, then there is no VISTA recovery at all, and none sold.
well RTM the manual covers that topic.
just read it./ on all PCs made ,.
NO OS told after all w10 has inside it reset.?
DOCUMENTED AT MICROSOFT.COM FULLY BUT NO OS TOLD;
HERE IS THE LIST OF WAYS. SAMsung RTM
1: USE THE DISK cd/DVD PROVIDEd BY SAM.
2; OR DAY1 YOU MADE THIS DISK PER MANUAL,oops
3: OR THE HOT KEY IMAGE WORKS. OR NOT.
4: BUY W10 AND LOAD IT. (most fail this old)
THIS IS A WINDOWS ANSWER, NOT BIOS RESETS NOT PW RESETS OR THE LIke.
JUST WINDOWS, BUT NONE TOLD, guess VISTA
#3 fails if hdd was replace or upgraded to ssd.
as that act kills dead the image.(c:)
and is a option new, for a fact.
https://www.samsung.com/ie/support/model...
100 % free to read.
