My coffee maker shows the error that I don't have water in the reservoir, but I do. It even shows up on the gauge.
Unplug the device and plug back in after 1 min. If it still fails, then you have a dirty water level sensor or the control circuit board is fried. Empty the water out and fill it with vinegar as full as you can without overflowing. Let it soak overnight and turn the machine on (without coffee in it). Turn off after 30 secs.Turn on again and allow it to finish the cycle. Discard the vinegar. Run three more brewing cycles with water only and it will be OK to use. If this does not cure it, then the only cost effective way is to replace it.
It has to do with salt build-up from hard water. Clean the machine. I put in more vinegar than suggested and ran vinegar through at least three times. It now works. No more "Empty water reservoir" icon.
On the water reservoir there is a little black disk, a magnet, I think... If that is not against the machine it will display the prime error. Empty the water from the reservoir and tilt it so that the disk is against the machine. Place the reservoir empty back on the machine and fill it with water carefully as not to move the disk. When the water level gets to the correct position, the prime error will go away.
In the user manual it says
What if F 10 shows?
- No water can be pumped from
the water tank.
- F 10 also shows, if the water tank
was not filled correctly during
descaling.
- Fill the system with water. See "Before
using the coffee system for the first
time".
- Remove and reinsert the water tank.
- Refill to the mark and restart descaling.
- If the message still shows, contact
Technical Service.
