According to the directions: Press B - bottom left button,to go into Alarm Mode. Press D - upper right button - to activate the alarm and press again to activate the Chime, which shows on bottom left as a bell. To activate these press D. To DEACTIVATE them press D again. Press B 3 times to return to Time Telling Mode. It took a few tries, but D and B are the keys to stopping that annoying chime!
Cat Holland, try this solution contributed by Jack Sharp:
To turn hourly beep on/off: Hold the RESET button (lower right) and press the MODE button (lower left). When the days of the week light up, the hourly beep is on; when the days of the week are off, the hourly beep is off.
To turn the alarm on/off: Hold the RESET button and press ST/STP (upper right). Alarm light will go on/off.
I don't know whether it will work for you but it worked for me...first time and every time. It's worth a try. Good luck! Chas.
I don't know wh
To turn off the hourly beep on a Mingrui sports watch, you can try the following steps:
Press and hold the "Mode" button until the watch enters the settings menu.
Use the "Adjust" button to navigate to the "Beep" or "Alarm" option.
Press the "Adjust" button to turn off the hourly beep.
Press the "Mode" button to exit the settings menu.
Please note that these steps may vary depending on the specific model of Mingrui sports watch you have. It's recommended to refer to the user manual for your specific watch for detailed instructions.
often this is a setting on the watch face. in my experience it is a bell looking object. for most sport watches, pressing a combination of the start and stop buttons will effect this setting. More Detail on the particular watch and i can be of more help
I have the answer how to stop the hourly beeping on watch f91w you press c button on left bottom and right button at same time as pressing left bottom button and that will remove the alarm pic at top and it will then turn off the hourly beeping. About the watch f91w.
To turn off the hourly beep: While holding the lap/reset button down, press the mode button. When all 7 day flags show, the hourly chime is on. When no day flags show, the chime is off.
