SOURCE: jazzy 1121 power chair won't charge when plug in
you have either bad batteries or a bad charger or the charger might have come unplugged at the controller or power module. When you have the charger plugged in and you turn on the joystick the lights on the joystick should ripple to indicate the charger is plugged in. If you don't see this ripple then either the charger is bad or disconnected. Trace the charger cable from the rear of the chair (you have to remove the seat and shroud to do this) to the front module and make sure that the cable is plugged in. Hope this helps
I suggest you print this out and keep it handy.
Locking/Unlocking the VSI
The VSI has a feature that enables you to
lock your power chair to prevent unauthorized use.
To lock the VSI:
1. With the VSI switched on, press and hold the on/off key. After 1 second, the VSI should beep.
2. Release the on/off key.
3. Push the joystick to the full forward position until the VSI beeps.
4. Pull the joystick to the full rearward position until the VSI beeps.
5. Release the joystick. There should be a long beep.
6. The VSI is now locked.
To unlock the VSI:
1. Press the on/off key and power on the VSI. The maximum speed/profile indicator should ripple up and down.
2. Push the joystick to the full forward position until the VSI beeps.
3. Pull the joystick to the full rearward position until the VSI beeps.
4. Release the joystick. There should be a long beep.
5. The VSI is now unlocked.
NOTE: If the above procedure fails to either lock or unlock the VSI, contact your authorized Pride Provider.
Lock Mode
To unlock the VSI:
1. Press the on/off key and power on the VSI. The maximum speed/profile indicator should ripple side to side.
Hope this helps
LOCKING/UNLOCKING THE VSI
The VSI has a feature that enables you to lock your power chair to prevent
unauthorized use.
To lock the VSI:
1. With the VSI powered on, press and hold the on/off key. After one (1)
To unlock the VSI:
Good Luck
mi mobility
I am assuming you have a Jet 7 with a VSI controller (manufactured by Penny and Giles) with a steady flash of all the speed and profile LEDs (lights). This is a no drive away feature of the VSI if the charger is plugged in. The older Penny and Giles controllers indicate the same flash code.
If you have an on- board charger check to see if it is plugged into the wall. If it is, unplug it and see if the chair runs. Sometimes, you have to remove the back cover and unplug the charger haress at the output of the charger inside the electronics housing (much more difficult). A failed on-board charger can inhibit the VSI controller (no drive away) even if it unplugged from the wall outlet. There is also a charger inhibit harness with a fuse that might have failed. A qualified technician can jumper this harness to bypass and test.
If you have an off-board charger unplug it from the wall or unplug it from the charging port in the front of the VSI. If the chair runs in either case you have a bad charger.
You may also have a bad VSI controller which can be rebuilt or replaced. Start with the basic charger unplug tests and then work your way to the VSI controller. Hope this helps.
