Lawn tractor model 247.288851 (craftsman) and grass catcher model 917.248971(craftsman). Back of tractor is not configure to mount the support brace for the grass catcher. Is there a missing mounting plate of something else?
SOURCE: I purchased a Sears lawn tractor model 28556. It
Get a free manual from www.managemylife.com
SOURCE: mounting snow blade to lawn tractor
It attaches the the front of the tractor. Similar to a plow to a truck. If you don't have the brackets, you will need those, or make your own. You can see a picture of the brackets if you go to sears.com. Click on the PartsDirect link at the top, and enter the blade model number.
SOURCE: Craftsman Lawn Tractor 17hp 42 model 917.271662 auto trans idles and bucks when cutting grass
The symptom that you are feeling is that your transmission is not fully engaging correctly. Basically you have a few different things to try depending on the trans that is on your machine. Drain the fluid and re-install new fluid, adjust your brake/clutch to make sure that you are fully disengaged and fully engaged when you release the pedal. If none of those 2 cure your issue then you are looking at a trans rebuild or replacement
