Televison & Video Logo
Corinne Jeffrey Posted on Oct 08, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Good mans tv with integral DVD player. GTV51DVD, attached free view box. TV worked for a week. Now showing a 5min countdown box each time the tv is switched on, then at 0 the tv goes on to standby. DVD player works.
Level 3:
Top Expert:
  • Televison & ... Master 76,851 Answers
  • Posted on Oct 09, 2013
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15008380
Points
237762
Check whether the off timer is set or not.
5 Related Answers
Anonymous
  • 3130 Answers
  • Posted on Oct 16, 2006
SOURCE: Sony shows a split screen when DVD plays
If the new player you hooked up is causing the spit screen then you have to go into the set up menu in the DVD player and take it out of prograssive scan.. Its in the wrong fornmat for your TV set. good Luck PS please dont forget to rate this.
Anonymous
  • 1284 Answers
  • Posted on Dec 01, 2007
SOURCE: Can't get my DVD player to work...
Your GE TV most likely doesn't have anything but a antenna input on it? If that the case to connect a DVD player you must purchase a RF modulator to convert the video and audio output of a DVD player to a channel 3 or 4 output. Here is a link for one at Radio Shack.
http://www.radioshack.com/product/index.jsp?productId=2103095&cp=&sr=1&origkw=rf+modulator&kw=rf+modulator&parentPage=search
Anonymous
  • 35 Answers
  • Posted on Dec 21, 2007
SOURCE: RCA CONSOLE TV will not work with DVD Player
what is the model of your tv and the method in which you are trying to connect the dvd (ie rca cable, component, composite, hdmi) and do you hear audio
Anonymous
  • Posted on Oct 17, 2008
SOURCE: Durabrand tv won't work with vcr/dvd player
I was given a dwt1905 tv for my kids without a remote so they would have a tv for there dvd player and games plus cable comes to find out I was not able to control anything I listed above with my cable remote because there is no codes you have to buy the remote from the company I called 3# before I was able to find out anything about a remote the contacted # is 1-800-242-7158 and the cost was 19.99 for a new remote that is the only way you will be able to work the tv with dvd player,game systems and cable I hope this helps........ good luck
ginko
Ginko
  • 19396 Answers
  • Posted on May 05, 2009
SOURCE: Standby Indicator flashing SONY KD-32NX100U
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1Theinternal circuits are jammed because of electrostaticcharges accumulating on capacitors, or because of a wrong voltage readby the main chip on your monitor controller board. this started theprotection circuit.
2 The protection circuit detected a wrongvoltage or abroken contact, identified an internal fault and kicked in, starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Payparticular attention at inverter and power board, power board can beinspected looking for bulged or leaking capacitors, then tested with amultimeter. The inverter is more difficult to test , there is need toread voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
2answers
DVD player is attached to tv but the tv screen is black with a box saying no video available
Is the DVD player connected to the television via an HDMI cable? You have to click Source or Input on the remote to move to that Socket.
Get RCA DVD Player to work.
ok on dvd player u wann use hdmi cable direct to tv ok then select input hdmi on tv remote to see picture
Mitsubishi VS-60805 Rear Projection won't operate in HD mode with Cable Box
Since this is an older first generation (1999) HD TV it may not be compatible with newer HDTV receivers because the standards back then were different - Make sure the HD cable box is plugged into the HD component inputs on the back of the TV (not the DVD inputs) and that the menu setting on the TV is set to DTV (not RGB) video. This TV will only accept 480i and 480p signals on the DVD input. Also the HDTV input will only accept 480i,480p and 1080i (it will not work with a 720p signal,make sure your cable box is not set to that mode)
DVD Player won't show recordings on my TV screen
put the dvd player on the same channel as you set your Tv when wathing direct tv. and try recording
if you are using rca push on cable yellow,red ,white set to your A,V audio,video channel
when recordining you will be changing channels on the direct tv box
do you have a manual for dvd player read that really good that might help.
2answers
I have an Onn 15'' LCD TV Model No OLCD1504 and am trying to connect a DVD player that only has an AV out.I have tried connecting it with a Scart to Av lead in all combinations i.e. via freeview box,direct...
Some dvd players do not have the switching line fro your tv to automatically select scart input but you will be able to select via the tv remote if there are no buttons marked av it can be an oblong with an arrow pointing inwards or you may have to select via the source menu on the tv if you have your original handbook it will give a helpline number for Asda.SUPER8.
2answers
Westinghouse LTV-32w4 HDC widescreen DVD Combo
Hi Mouse999. From reading a bit, it seems that there's no region free hacks for the built in dvd player in that specific model. A solution for you, would be to purchase a standalone dvd player, one that is region free or one that has a region free hack available, and to connect it to that tv. If you're in europe and your tv is pal, you also need to have a dvd player that will read both Pal and NTSC video dvd's ! If that doesn't help, please be more specific, i'll be glad to help. Thanks, cheebster.
Son pressed something and now DVD won't work
well there could be two things going on here that i can think of, one the scart lead between the dvd and the tv is not i properly vica versa for the dvd player, the other thing is the button which changes the av channels could have been pushed so simply push the button while the dvd os on and find the av channel, the button looks like an arrow going right hope it helps.
Hooked up don't work
Hook the DVD Combo unit to the Video input of the TV. Not through your Dish Box. Then to View the DVD/VCR, switch the TV to the Video Input. Good Luck and have a great weekend
Ed
NC Electronic
Mills, Wyoming
LASONIC DVD PLAYER NOT WORKING WITH COMCAST BOX OR SOYO TV
you have to plug everything to the tv. only thing them are good for is recording to some other unit. like dvd recorders
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
