Yes you can.remove two screws from under one side pull it away slightly and it will come away.you will then have one housing on both sides left in the fridge wall,they will have a little pressure on them from the springs. just prise them away. you will need help to replace them, as you need pressure against the spring to keep the door closed. you can buy springs and housings seperately from camec there is left and right housings.give me a call if you need to ..
On some models you don't have to pry the door in any way. Look up under the closed door on the right side and you will see a small hole there. Put an eighth inch diameter nail through the hole and push until you feel the spring compress into the hinge housing. The door will release from the hinge and come out towards you. Then lift the left side out. You can get the hinge housings on Ebay. That is usually what breaks. Look for upgraded parts.
You can get all the hinge parts on Ebay
