Then select Settings > Call Blocking or Blocked numbers and add the number you want to block. You can also go to Call history or Recent calls and tap the number you want to block, then select Block. Here, you can also Report call as spam.
If you subscribe to Caller ID service, your phone can block calls from up to 20 specific phone numbers. This is called the BLOCK LIST. It can also block any call that does not provide a phone number with the Caller ID. This is called CALLS WITHOUT NUMBERS. In either case, the caller will hear a busy signal, and the call will be disconnected.
To add phone numbers to the BLOCK LIST:
When the phone is idle, press MENU/SELECT.
Press VOLUME? until you see Call Block, then press MENU/SELECT. Block list is displayed. Press MENU/SELECT.
Press VOLUME? until you see Add new entry, then press MENU/SELECT.
Enter the complete phone number of the party you wish to block, then press MENU/SELECT.
Enter the name of the party, then press MENU/SELECT.
To activate the CALLS WITHOUT NUMBERS feature:
Press VOLUME? until you see Calls w/o num, then press MENU/SELECT.
Press VOLUME? until you see Block, then press MENU/SELECT. All calls without a phone number will be blocked.
By using truecaller you can block a caller or go to phone setting to block calls, open the Phone app, select Call History, tap the number, then select Block Contact or Block Caller. To block calls, open the Phone app, select Menu > Settings > Call Reject > Reject Calls From and add numbers. To block calls for numbers that have called you, go to the Phone app and open the Log.
To block calls, open the Phone app, select Call History, tap the number, then select Block Contact or BlockCaller. To block calls, open the Phone app, select Menu > Settings > Call Reject > Reject Calls From and add numbers. To block calls for numbers that have called you, go to the Phone app and open the Log.26 Sep 2016
To block calls, open the Phone app, select Menu > Settings > Call Reject > RejectCalls From and add numbers.
To block calls for numbers that have called you, go to the Phone app and open the Log. Select a number and then More > Block settings. There you will be able to select Call Block and Message Block.
Using Call Block If you subscribe to Caller ID, you can save phone numbers to the call block list. When a call comes in, the phone compares the received phone number to the numbers on the call block list. If the phone number is on the list, the phone replaces the caller's name with Call Blocked and disconnects the call. (The caller hears a reject tone.)
The call block list holds 20 entries, and all stations share the same list. You can add entries through the Call Blocking menu, by selecting Add Call Block in the CID menu, or by blocking incoming calls. (Only one station can edit the call block list at a time.) Blocking incoming calls
When the phone rings, wait until the display shows the Caller ID information (usually after the second ring).
If you want to block the call and add this number to the call block list, press Block.
When the phone asks you to confirm, press Menu/select or Block. Blocking an incoming call from an "Unknown" or "Private" number is the same as selecting Unknown Number or Private Number from the Call Blocking menu.
Call Blocking menu options
With the phone in standby, open the menu and select Call Blocking.
Choose one of these options:
Create New(Handset only) - Add an entry to your call block list. The phone will prompt you to enter a name & phone number.
Private Number(Handset only) - Block all calls from numbers reported by CID as "Private." (This does not count as one of the 20 entries.)
Unknown Number(Handset only) - Block all calls from numbers reported by CID as "Unknown". (This does not count as one of the 20 entries.)
Call block entry options
With the phone in standby, open the call block list and find the entry you want.
Press Menu/select to open the individual entry menu. Choose one of these options:
Edit(Handset only) - Edit this entry. The phone will prompt you to edit the name & phone number.
Delete - Erase this entry from the list & allow calls from this number.
To block calls on your Curve: 1)In the phone, press the Menu key 2)Click Options 3)Click Call Barring 4)Highlight the call blocking option you want 5)Press the Menu key 6)Click Enable 7)Type your call blocking password. To stop blocking calls, highlight a call blocking option, click the Menu key and select Disable. Please note that call blocking is not associated with your device, but instead with your carrier and your SIM. You will need to contact your service provider to purchase/enable call blocking – they will provide you with a password for the set-up listed above (which, by the way, I lifted directly from my Curve – must give credit where it is due!). Hope this helps!
if you want to block your own number dial *67 before you dial... to block someone else try dialing
To activate Call Block or add a telephone number to the rejection list, dial *60. If you dont know the number to be blocked, dial *60 immediately after hanging up from the call. To turn off Call Block, dial *80. Call Block cannot block calls from some cellular phones, pay phones or business lines. It also cannot block most long distance numbers.
