20 Most Recent
Philips DECT VOIP-321 cordless telephone Questions & Answers
No voice for dial
Talk to Philips support at: http://www.support.philips.com/support/contact/contact_page.jsp?userCountry=ca&userLanguage=en
VOIP 321 will not work with Windows 7
VOIP 321 is working with windows 7. Install the Vista Software. After that you change compatility under properties (right mouse klick) to windws vista and it works fine regards kurt
Use call phones through voip321
It took me a while to figure out but here is how I am able to dial out from skype to a hardline to a person not in my skype contact. Simply start to dial the number (not from the talk button!!!) then instead of hitting the talk button to dial, hit the skype button on the bottom left hand side. I also have to dial 001 then the phone number. Hope this works for you too. good luck.
Contact list not available on voip321 handset
Using Skype 3.8.0.180
Go to Menu-Tools-Options-Advanced and give your voip321 access to skype application.
I had the same problem, solved when I allowed the skype phone to access skype.
Cheers
Philips 321 voip phone, problem calling out with skype
some things to consider
Have you topped up credit on skype?
dialing code correct uk +44, mobile number +447958475236 ect?
if this does not work look in your manual and reset your phone and try again
regards
Muzzi_123
Skypeout call problem
It seems you need to dial the Country Code as well as the area Code and Telephone Number: ie:00-1-(area code) - number, as the call is routed through the UK
