SOURCE: dwd f1011 washing machine, error codes E2&E9, machine not working
the E9 error code problem could be with door switch wiring, the door switch or the control board.but E2 problem occurs when a button is pressed for more than 30 seconds.Check for any such button else the problem is surely with the control board.
SOURCE: fault codes for indesit washing machine, the display shows F-08
F08 means that the heater relay is stuck or cannot be activated for some reason, this has the effect of stopping the water heater from working.
The only thing you can do is to test the heater, and see if it is o/k.,if it is , then you there is not much else you can do, except call an engineer.
Plz rate my solution.
Thanks.
SOURCE: Miele Washing Machine Code: Check drain
This means that the drain attached to the pump is clogged, remove the drain plug check fro debris and replace...you should be good to go.
SOURCE: what does the code 5d mean on my washing machin???
5d is actually SD
it means SUDS
you have suds detected in the pump
Your using too much soap and the machine cannot rinse it
try one load with out any soap
from that load on you should not be using any more that a table spoon per load
SOURCE: fisher & paykel washing machine fault codes
I have a Fisher & Paykel GW609AU Smartdrive Excellence 6.5 Washing Machine that would start then stop then start then stop a few more times before eventually beeping.
I fixed it by bypassing(joined the white and yellow wire) the trip out switch which is located under the control module(one screw to remove).Now it Works.
