1997 Cadillac DeVille Logo
James Wenger Posted on Sep 23, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
97 Cadillac Delegance Front end noise , dissapears when going into right hand turn then returns when straightening out. Tires recently rotated and balanced , tire that was on right front had wear pattern more visible then the other tires , Wheel Bearings ?
Bill Boyd
Level 3:
Top Expert:
  • Cadillac Master 53,816 Answers
  • Posted on Sep 23, 2013
Bill Boyd
Cadillac Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11951214
Points
172802
I would be checking out the wheel bearings for the problem. I would also be checking the front suspension for worn ball joints and steering end joints. Tyre wear patterns indicate unbalance-wheel alignment-shock absorbers and front end wear. I refuse to rotate tyres for several reasons Radial tyres when developing a wear pattern will retain that wear pattern even if placed on a trailer--Wear patterns show a fault for that wheel and tells which wheel and what needs to be done to repair it and lastly tyres wear in pairs so if you have a front wheel drive car why replace 4 tyres when the need is to replace only 2 front ones. Saves about 50% of the cost of tyres. The rotation theory came about from cross ply tyres and does not apply to radials except for tyre dealers profits
  • James Wenger
    James Wenger Sep 24, 2013
    Thanks Bill a great help on this one , Due to starting a new job and the tight $ situation , can I replace the one side hub assembly and not have to do the other side at the same time , I know garages typically will tell you both sides at the same time.
  • Bill Boyd Sep 25, 2013
    provided that the disc brake rotors are seperate items to the hubs there is no reason to replace both hubs . It only becomes a problem if the hubs and rotors are a unit in which case you will have to replace both to maintain even braking
4 Related Answers
Anonymous
  • 2920 Answers
  • Posted on Jan 11, 2009
SOURCE: cadillac Deville 1996 front end waddles at slow speeds.
it sounds like you may have a bad set of wheel bearings on one side or the other.which would mean you have a bad cv joint or one that is going bad. you may want to try to figure out which side the wobble is on and inspect that side.i suspect its going to be the side where you had the problem with the tire.
Anonymous
  • 45 Answers
  • Posted on Jun 30, 2010
SOURCE: I get vibrations in the front end when I am going
You need to have your tie rods checked out. Most of the time it will be your tie rods or your wheel bearings. You can replace your tires all day long, but it will not fix that problem.
Anonymous
  • 613 Answers
  • Posted on Sep 14, 2010
SOURCE: 2004 Cadillac Deville passanger front
yes your tire is unbalanced and needs rebalanced like 20 dollar fix have all 4 done
Anonymous
  • 6982 Answers
  • Posted on Mar 20, 2011
SOURCE: I have abnormal wear on
Tire wear as you outlined is caused either by incorrect toe in or camber setting. Both are components of wheel alignment. Regardless of what you were told, there is no other way that happens.
As to who gets to pay for it depends on your agreement.
I am getting a definite road hum off the front of my 2003 Envoy. when I rotated tires it seemed to quiet it but than returned. I suspect wheel bearings but it doesn't get louder when turning the wheel...
Usually this is a sign that you need an alignment. Do previous front tires show any wear on the corners? My guess is that the noise returned when the new front tires "broke in".
1helpful
I just bought an2003 ford explorer 4x4 and i have a loud humming noise coming from the front end tires are brand new it has around 190,000km please help
If the noise is only when the vehicle is moving it sounds lek you have a bad wheel bearing. You can inspect ford move ment or play shaking the tires up and down and left to right while lifted up on hoist or jack. If there is no movement doesn't necesarily mean the bearings are okay, however if there is movement in bearing replace and drive again. Antoher way to determine Which wheel bearing is bad is to drive and turn to the left, if the noise gets louder than it mens the rightside wheel bearung is bad. If you turn to the right and noise gets louder replace driver side front wheel bearing. Also Rub your hands across your tires, does it feel wavy or uneven, you could have cupped tires, I DON'T KNOW HOW NEW THEY are but cupped tires will also make this noise. One way to see if it is the tires is to do a rotate If noise changes at all then you no its a tire causing noise. Hope this helps.
My 2005 avalon has 154,000 miles on it and I'm getting a noise from the front end, expecially when I turn sharply to the right or left. I have the tires rotated and balanced every 6,000 miles. Would this...
sounds like it could be wheel bearings but I'm surprised that when they rotate the tires they didn't catch this.
The next time you have your tires rotated ask to have the jacked up front end tested for loose front end parts. They can shake it down physically looking for play in the ball joints, tie rod ends, and bearings.
Struts generally wear out and cause a bouncy front end conditioin. Brakes, if properly assembled, won't make any additional noise when turning left or right.
Good luck on this.
2answers
Front end vibration on 2002 cadillac. Everthing done. Still vibrates at about 65 miles an hour
honda had the same problem in the eighties and fitted a weighted ring onto the longer of the two driveshafts,just a thought,(i supose if someone comes up with the solution GM will pay them for the R & D.)YEAH RIGHT.....
regards
geoff
england.
Whining noise from front end while driving
you have a bad front wheel bearing..jack up front of vehicle..put in neutral..block rear wheels..put 1 hand on front coil spring and rotate wheel..you will feel roughness in spring on side that wheel bearing is bad
2000 Jeep Grand Cherokee front end howling
still sounds like bad tires to me.  is it an engine or belt noise?  Is it a whistle?
Front End Problems
first i would check the tires , are they cupped or chopped on the tread? run your hand over the tread and see if it feels rough and uneven. take the truck to a auto repair shop and have them jack both front and rear axles off the ground, put the truck in 2 wheel drive and run the speedometer to the speed you usually hear the roaring noise, if you don't hear the noise , put the truck in 4 wheel drive, turn off the traction assist if it has one and run it to the speed you would hear the noise. if you hear the roaring noise with tires off the ground, the problem is in the drivetrain, (engine, transmission, transfer case, u-joints, differentials or the front left or right cv halfshafts or u-joints). the older models (97 98) had the front two driveshafts from the differential turning all the time, they engaged in 4 wheel drive from the transfer case and a solenoid on the front differential. depending on the miles you have on this truck, the most likely areas i would look at would be the tires, u-joints/cv joints, and front and rear wheel bearings. thanks and good luck.
Wobbly front end w/ a pop noise when turning
on the wobbly have the tires inspect for posible broken belts, or rotate the tires and if gets better that means you have broken belts on one or two tires and need a new one, and on the poping just have it inspect for an auto repair, you can fin one here for your area in the home page just look for services and type your zip code
Top Cadillac Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Cadillac Expert? Answer questions, earn points and help others
