Whirlpool ET8CHEXSQ Dryer Logo
Posted on Apr 18, 2009
Whirlpool cabrio steam electric dryer has sensor light on and does not work
Whirlpool electric cabrio dryer has sensor light on and does not work
  • 1 more comment
  • Anonymous Jul 01, 2013
    my whirlpool wed9200sq is still flashing f1, and we replaced the cntrl electric that we were told to do. all the lights work, but it just clicks the drum does turn or heat
  • Anonymous Mar 17, 2014
    does cabrio whirlpool dryer use any oils?
  • Anonymous Mar 31, 2014
    Whirlpool Cabrio Dryer door gasket keeps slipping off Can you glue it on or outright replace it
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Oct 14, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
5237
Points
29
Have a problem with my cabrio dryer its powered on but when i push start the sense like comes on and does nother whats the problem
Anonymous
Level 1:
  • Posted on Apr 26, 2012
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
5237
Points
I have exactly the same thing going on. Repairman suggested you have the venting all the way to the outside of the house cleaned. Of course, I spent the $$ doing that; it was clear! The next thing to fix is the entire sensing board on the dryer. I might add, mine is less than a year old. Should have looked at this site before I purchased the set!!!
My Whirlpool Cabrio dryer has water leaking in it. How do I fix this or what's causing it?
This model has steam support, so it should have a cold water connection to it. Check for leaks where the hose connects to the rear of the dryer. If you do not use the steam feature, you can shut off the water and that will probably end your problem.
The control panel of cabrio dryer wed6600 has air bubbles where function area control are. It works fine but looks bad. Should I pull it up and press it down?
None othe these answer actually answer the question, the question is about a cometic issue. To the person who posted this this question have you figured out a way to fix it?
Pleas note that the dryer was running when this pic was taken.
1helpful
Dryer will come on but wont start. Sensing light is on
-There are couple things that cause a dryer no to work:
-Thermal fuse, heater element, door switch, start switch.
Good luck
Mai
How hot does a whirlpool cabrio dryer get
It can because it has a water line coming from washer line it causes steam for you dryer.
1helpful
2answers
Whirlpool cabrio wed6200sw0 dryer runs, won't heat up. blows air, lint line is clear and hi limit thermostat and thermal cutoff okay (have continuity) at room temp
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
1helpful
NEW Electric Whirlpool Cabrio Steam Dryer; NO HEAT
Check temperature sensor.  Check to see if heating element is OK.
Top Whirlpool Dryers Experts
Virgil Watts
Paul Bade
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
