It means that the Chasis or the cabinet which holds the motherboard, CPU, GPU, etc. is open. It's a security feature offered by some OEMs where a connector found on a motherboard can detect if the chassis component has been removed or replaced. Some OEMs also offer onboard speaker or PC chassis speaker which goes off in situations like these.
This is a hardware problem, and in most of the situations, you need to put the jumper back on the motherboard with the pin labeled chassis signal and ground. Sometimes OEM offers a simple switch which is automatically armed when you close the chassis properly. So check if that's the problem you are facing.
SOURCE: Error Boot "Chasis Intruded fatal Error System Halted"
Well it seems like that the cmos battery is down. You need to do the following
Change the CMOS battery,
Enter into bios and change the date and time properly,
Save and exit bios.
Now you should be able start your computer in windows.
SOURCE: Chassis Intruded, Fatal Error.....System Halted
I'm not familiar with that particulat model, but I'd guess the motherboard has a chassis switch connector, and senses the chassis be open. Could be because: - chassis open (close it), - switch defect (as a workaround, you could short-circuit it, or just unplug it - whichever solution works for you). As another workaround, you can probably disable this switch in BIOS.
SOURCE: Chassis Intruded, Fatal Error...System Halted
you need to go into the bios of your pc.....usually pressing the delete key when you see the first logo screen after booting up....look for a section that relates to errors and what the bios is supposed to do when it encounters an error.
i.e if you see a line in the bios that says "halt on all errors" disable it and when you next boot up the bios will not stall.
SOURCE: how to fix chassis intruded ..fatal error..system
It is unlikely that your CPU is damaged
You need to enter the BIOS and turn off chassis intrusion.
It is an option in the bios that is only useful if you have the switch on the computer case that supports it otherwise it will give you the error you see if enabled
SOURCE: Chassi Intruded" then "Fatal Error...System Halted" asus pvc5mx
okae...
first should you do is.. buy a new motherboard.. because like my motherboard, there is no solutions for that error nd problem...tnx
