do the next test. God bless you
- Reset component settings.
Usually, the problems you encounter with a projection TV may be resolved
through the resetting to its factory settings. If you experience
inaccuracies in the color, reset the television's PerfectTint/PerfectColor
capabilities. Simply press the Menu tab and then highlight "Perfect Color"
using your right key arrow. After this, press "Enter" and then "Reset" in
order to reset to factory settings. If you have audio / video problems
(VCR or DVD player), simply press "Menu" and highlight the "Reset"
option.
Reset television controls. In case you cannot fix your TV via its
component settings, there are other ways of resetting. Just select "Menu", key
in "1, 2, 3", and then press "Enter." In doing this, the TV's
manufacturer's specifications will all be restored. If your TV's power system
does not function, you should perform a complete system reset. You can do this
by clicking on Reset System button located at the TV's control panel. Your
television will be turned off and then a green light (LED) will quickly flash
for approximately one minute. Once the light has stopped flashing, your TV
should immediately turn on.
