Pioneer PDP-4350HD 43 in. Plasma Television Logo
A
Anonymous Posted on Sep 15, 2013
Speakers no audio
2014 dodge advenger radio wiring harness diagram
2014 Dodge Avenger Car Audio Wiring Diagram
Car Radio Battery Constant 12V+ Wire: Red/Brown
Car Radio Accessory Switched 12V+ Wire: N/A
Car Radio Ground Wire: Black
C
Car Radio Antenna Trigger Wire: Gray/Orange
Car Audio Front Tweeter Size: 2-1/2? Tweeters
Car Audio Front Tweeter Depth: 5?
Car Audio Front Speakers Size: 6? x 9? Speakers
Car Audio Front Speakers Depth: 4?
Left Rear Speaker Positive Wire (+): Dark Green/Tan
Left Rear Speaker Negative Wire (-): Dark Green/Gray
Right Rear Speaker Positive Wire (+): Dark Green/Brown
Right Rear Speaker Negative Wire (-): Yellow/Gray
Car Audio Rear Speakers Size: 6? x 9? Speakers
Car Audio Rear Speakers Depth: 4?
2answers
Audio-Technica AT-LP120 turntable. I have crackling in the passive speaker, but when I reverse the speaker wire,ie, red in black & black in red, the crackle appears in the powered speaker.
If you have replaced the cartridge then it must be the cartridge pre-amp that is faulty. If there are any other functions on the device such as CD, then it will not effect them. Unless there is crackling on any other function then the pre-amp has a problem. The pre-amp itself is generally a single IC. You can find it by following the turntable connection back to the inside of the amp. The signals will pass through the IC before being passed to the main pre-amp.
1helpful
2004 ford explorer sport track radio wire colors
Hi there:
Check this on 2004 Ford Explorer Sport Trac Audio Wiring Schematic:
Car Radio Battery Constant 12v+ Wire: Light Green
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Dimmer Wire: N/A
Car Stereo Power Antenna Trigger Wire: N/A
Car Stereo Amp Turn-On Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Tweeter Size: N/A
Car Audio Front Tweeter Depth: N/A
Car Audio Front Tweeter Location: N/A
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): Dark Green/Orange
Right Front Speaker Negative Wire (-): White/Light Green
Car Audio Front Speakers Size: 6" x 8" Speakers
Car Audio Front Speakers Depth: 2 1/2"
Car Audio Front Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
Car Audio Rear Speakers Size: 6" x 8" Speakers
Car Audio Rear Speakers Depth: 3"
Car Audio Rear Speakers Location: N/A
Car Subwoofer Speaker Size: 8" Subwoofer
Car Subwoofer Speaker Depth: 4"
Car Subwoofer Speaker Location: N/A
Car Subwoofer Speaker Positive Wire (+): N/A
Car Subwoofer Speaker Negative Wire (-): N/A
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
2005 nissan pathfinder xe 8 speaker wiring COLOR
Check this for...
2005 Nissan Pathfinder with Bose Audio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Yellow
Car Radio Accessory Switched 12v+ Wire: Green/Black
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Red
Car Stereo Dimmer Wire: Gray
Car Stereo Antenna Trigger Wire: Green
Car Stereo Amp Trigger Wire: Green
Car Stereo Amplifier Location: Under the Driver Seat
Car Audio Front Speakers Size: N/A
Left Front Speaker Positive Wire (+): White
Left Front Speaker Negative Wire (-): Black
Right Front Speaker Positive Wire (+): Yellow
Right Front Speaker Negative Wire (-): Brown
Car Audio Rear Speakers Size: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Black/Red
Right Rear Speaker Positive Wire (+): Blue
Right Rear Speaker Negative Wire (-): Black/White
2005 Nissan Pathfinder Car Radio Wiring Diagram
Car Stereo Amp Trigger Wire: N/A
Left Front Speaker Positive Wire (+): Brown
Left Front Speaker Negative Wire (-): Blue
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Red
Left Rear Speaker Positive Wire (+): Green
Right Rear Speaker Positive Wire (+): Gray
Right Rear Speaker Negative Wire (-): Orange
Radio wiring hook up
1996 Dodge Avenger Car Radio Stereo Audio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink/White
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Illumination Wire: Orange/Brown
Car Stereo Dimmer Wire: Black/Green
Car Stereo Antenna Trigger: N/A
Left Front Speaker Positive Wire (+): Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Blue/Red
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Blue
Right Rear Speaker Positive Wire (+): Blue/White
Right Rear Speaker Negative Wire (-): Blue/Orange
1996 Dodge Avenger with Infinity Audio Car Radio Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Red
Car Radio Accessory Switched 12v+ Wire: Blue
Car Radio Illumination Wire: Green/Orange
Car Stereo Dimmer Wire: Green/Yellow
Car Stereo Amp Trigger Wire: White/Black
Car Stereo Amplifier Location: Mounted under the rear deck. Some models have a black plastic trim covering the factory amplifier.
Left Front Speaker Positive Wire (+): White/Blue
Left Front Speaker Negative Wire (-): Black/Blue
Right Front Speaker Positive Wire (+): White/Red
Right Front Speaker Negative Wire (-): Black/Red
Left Rear Speaker Positive Wire (+): Yellow/Blue
Left Rear Speaker Negative Wire (-): Gray/Blue
Right Rear Speaker Positive Wire (+): Yellow/Red
Right Rear Speaker Negative Wire (-): Gray/Red
pls rate
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
3helpful
I have a 98 camaro and need to know what wires go to the new wires of my aftermarket stereo
1998 Chevrolet Camaro Car Audio Wiring Diagram
Radio Battery Constant 12v+ Wire: Orange
Radio Illumination Wire: Gray
Stereo Dimmer Wire: Brown Stereo Antenna Trigger Wire: Pink
Audio Front Speakers Size: 6 1/2′
Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Negative Wire (-): Dark Green
Audio Rear Speakers Size: 6 1/2′
Audio Rear Speakers Location: Side Panels
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
I need to know the audio wiring for a 1993 caprice classic
1993 Chevrolet Caprice Car Audio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: Pink
Car Audio Front Speakers Size: 4′ x 6′
Car Audio Front Speakers Location: Doors
Car Audio Rear Speakers Size: 6′ x 9′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Negative Wire (-): Yellow
pls rate
Top Pioneer Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
