The reason why you can't play MP4 on TV is that your TV doesn't support the file format that you are playing. I found an article may be helpful to you. You can have a check. It's about why MP4 cannot be played at TV.
https://www.leawo.org/tutorial/some-mp4-files-wont-play-on-sony-tv-solved-1372.html
You could use Leawo Video Converter to convert video format at first. https://www.leawo.org/tutorial/4-best-free-online-video-converters-to-convert-video-to-mp4-files-online.html?=1395
SOURCE: Connecting LG 42PG20 TV to Samsung HT-Z320
output on TV cable digital reciever to home theater digital reciever in via an optical cable.lower the volume on the TV cable digital reciever to get the most out of the surround sound system.
SOURCE: how can I get sound from my tv through the home
purchase a fiber optic cable if ur tv supports it
SOURCE: i have a samsung HT-Z320 home theater system. when
the player's amplifier is blown and needs to be repaired or replaced.
SOURCE: HT-Z320 displays PROT code and then shuts down
i had the same problem a prot display then it would shut down. turns out i had the sub disconnected(noise complaint from the shaking at my apartment complex) but the speaker wires for the sub connected to the amp or central unit. when i disconnected the sub i left the wires on the floor behind the sub separating the pos. and neg. somehow the wires got moved around and the pos was touching the neg. as soon as i noticed and fixed this problem the system was working fine. my samsung hometheater model is HT-BD1250
