I have a Frigidaire front load washer and the bearings that support the drum are making noise when it spins model #CLTF 2070 CSO..is it hard to replace the bearings and is there any special tools needed ..how do I remove the rubber ring by the door so I can remove the external plastic drum....thanks
SOURCE: Frigidaire top-load washer Loud noise during spin
its either the upper spin bearing or lower spin bearing. the upper can be replaced by itself but the lower requires the transmission the be replaced
SOURCE: load noise in final spin cycle
turn the tub on the inside if it feels ruff as it turns and makes a noise then most likely you have a bad rear bearing, if it is smooth in turning and no noise then turn to drain or spin possibly something stuck in drain pump. the drain pump will start up first if you hear the noise then the drain pump is accessed from the front lower cover, if its the rear bearing probably not worth fixing about 400.00 in parts and alot of work.
SOURCE: drum makes loud noise when spinning
The bearings are worn out ,it's not worth to repair , the fact that your washer is old it's going to have more problems.
SOURCE: frigidaire front load washer model LTF530DS loose drum
I have the same issue with the broken spider...in the us and they say it is $300 for labor and $360 for parts. My washer is only 3+ years old...what can I do?
SOURCE: bearing on front load washing machine needs replacing (Frigidaire
You will need to replace the tub rear shell/bearing assembly (part # 131525500).
To do this, practically the whole machine will need to come apart.
To remove the drive pulley, remove rear cabinet panel. Remove the pulley screw and pull back on the pulley (you may need to giggle it as you pull to remove it).
For the shock pins, grab the open end with a pair of vise-grips. On the "pointy" side of the pin press the tab in with your finger (if you can't push the tab in slide a 9/16" socket onto it) and pull the pin out with the vise-grips (twist back and forth slightly as you pull).
A qualified tech could replace the rear shell/bearing in about 1.5 - 2 hrs. I can certainly give you more help if you need it, let me know.
