SOURCE: forgot log on password and user name
Pls remove the Hard Drive and connect with another working PC as secondary .Login through administrator and open the drive where the OS installed which one not able to login and follow the path.
Windows/system32/config/SAM file
delete the SAM file .after that connect the Hard drive as Primary and check hope fully it will resolve.
SOURCE: I forgot Admin Username and Password
Here is an easy way to reset your forgotten administrator password
Prepare two things:
CD or USB, Windows Password Breaker
Steps:
Step 1: Download and install Windows Password Breaker.
Step 2: Burn a password reset CD/USB with the program.
Step 3: Reset password with the burned CD/USB.
SOURCE: forgot password and unable to do anything now
If you forgot the windows login password and want to recover or reset windows password, there is two methods to reset windows login password:
Methods 1: Use the password reset disk to recover the Windows password, by this methods, you need create a Windows password reset disk before you have lost or forgotten your Windows admin password.
Method 2: Using Windows Password Recovery software to recover Windows password
As an easy method to recover the forgotten Windows password, there are only four steps as follow:
Step1: Download Anmosoft Windows Password Reset V8.0( http://www.resetwindowspassword.com
)and install it.
Step2: Burn the ISO image file onto a blank CD/DVD or USB.
Step3: Boot up your Windows PC by the bootable burned CD/DVD or USB in minutes.
Step4: Remove the forgotten Windows password on the operation interface and logon PC without password.
