Actually the basic problem i am facing is dat in my computer option i am unable to browse all the drives of my computer even by exploring it...as i click the option..it just freezes and nothing else happens...getting an error message of script error...what to do?i am able to access all the stuffs from command prompt as i am getting confirmed that drive is healthy as it is listing all the files available
Most of those Windows to USB applications are for creating an Windows USB installation, not actually installing an operational OS on the USB. Does that make sense?
You would have to run the setup and choose the drive to where to install the OS. This would mean you would have to do it from a CD/DVD disc or have two USB drives, but this may cause a conflict.
HP is a reckoned organization, which is dominating the IT market interms of performance and security. Various models of computers andperipherals of HP are available in the market, which are demanded forsuperior performance and high processing speed. But, even HP systemsare not resistant to technical issues and improper handling or someother reason might cause some technical issues that you can fix on yourown.
General issues that you can face while using HP products are enlisted here:
- Performance issue - Slow boot/ startup activity - Installation and upgradation issue - Online threat - Network setup and configuration issue - Driver compatibility issue - E-mail access issue - Internet not working
Here are some of the basic steps that you follow to fix a slow running Internet
1. First method
Step 1. Click Start > Control Panel > Network and Internet Connections. Select "Internet Options."
Step 2 . Under Check for newer versions of stored pages, click "Automatically." Under browsing history, click "Settings."
Step 3. If you're using dial-up, set the number under Disk Space to Useto between 250 and 1024 megabytes (MB). If you're using a DSL or cableconnection, set it between 50 and 75 MB. Click "OK."
2. Second method
You must be familiar with cache memory, which is often called astemporary memory and stores the temporary files of the web pages thatyou have visited. These temporary files need to be deleted as theyacquire a great portion of memory and may slow down the performance ofyour computer as well the speed of your Internet connection:
Step 1. From browsing history choose "Delete" option.
Step 2. Click "Delete files" under Temporary Internet Files to clear your browser cache.
Step 3. Click "Delete cookies" to remove all cookies from your hard drive.
Now, you will get your Internet browsing much faster that’s too without any investment.
As a knowledgeable user, you should manage your data e efficiently. Ifyou are facing any issue in your HP computer, you can call yourtechnical team who is offering tech support to your HP computer.
2. On the Windows Start Menu select Computer or My Computer Depending on the OS
3. Browse to the following location: C:\Program Files\iTunes. Note: Windows 7 (64 bit)browse to C:\Program Files (x86)\iTunes.
4.Right-click on the iTunes application (iTunes or iTunes.exe) and select Properties.
5. Next select the Compatibility tab.
6.Ensure that the options Run this program in compatibility mode and Run this program as an administrator are not checked. If they are checked please deselect these options, then select Apply, and OK. You should now be able to open iTunes with out receiving the error message about iTunes running in compatibility mode.
This should fix your problem.Still if your facing the same problem after performing the following steps:-
7. Open the Registry Editor by selecting the Windows Start button, typing regedit into the search box or the run box depending which OS your using eg- xp,vista,7 and then pressing Enter.
8. Browse to the following location in the registry editor, HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Layers, and highlight the Layers folder.
9. Delete the entry for the iTunes application (iTunes or iTunes.exe).
10. Close registry editor and restart the computer
You should now be able to open iTunes without receiving the error message about iTunes running in compatibility mode.If not please reply
Im assuming you want to delete browsing history. You can go to Internet options in the control panel and delete browsing history there but to completely remove history files you need to delete the index.dat file.
This file, if you're using windows XP can be found in different places:
C:\Documents and Settings\<username>\Cookies\index.dat C:\Documents and Settings\<username>\Local Settings\History\History.IE5\index.dat C:\Documents and Settings\<username>\Local Settings\History\History.IE5\MSHistXXXXXXXXXXX\index.dat C:\Documents and Settings\<username>\Local Settings\Temporary Internet Files\Content.IE5\index.dat C:\Documents and Settings\<username>\UserData\index.dat
If you are using a different operating system, just search for index.dat and make note of the locations.
Once you've noted where the locations are you need to restart the computer and log in using safe mode. In safe mode pull up a cmd screen by going to start>run> then type cmd and hit enter.
In the cmd screen change directory by using the command cd C:\Documents and Settings\<username>\UserData for example and then del index.dat (to delete the index.dat file).
This is a system files. These are basic file's in a window directory.Regarding aquatica.dat, it is a multimedia file component.
You can repair this by downloading .dat file from .dat database. You can easily search the file online and add it. If you purchase a software, it would cost you certain bucks. Better reinstall windows or restore.
Computer can be affected by the missing of these files. It depends on How many files are missing, configuration of the PC, Virus, Malisware, Adware etc.
The simple option - Restore or Reinstall, if not a tech.
first insert your pendrive.Now right click on my computer.Go to manage option . select disk management. From that you must select your drive letter for your pen drive.Go to Action menu near to File menu.Fromthat select all tasks and select formatting.Then again goto all tasks and select change drive letter and paths.select the drive letter and your problem is solved. thanks for asking your problem.
(WARNING: After running this low level format tool, the whole USB flash disk surface will be fully erased. Therefore, data restoration will be impossible after using this utility!)
