The red reset button or ECO or energy cut off turns off power to electric water heater.
The ECO responds to temperatures in excess of 150 degrees F.
Preliminary work:
You can use thermometer to check water temperature immediately after ECO trips.
Compare water temperature against the thermostat setting.
There are 4 things that can cause ECO to trip:
1) Bad thermostat is sticking and letting element continue heating water, or ECO is reading incorrect temperature.
2) Factory installed insulation and cover missing from tank, and thermostat is exposed to cooler air and misreads tank temperature.
3) Element shorted to ground in center of element. This completes 120V circuit to ground which will cause element to continuously heat the water.
4) Loose wire near ECO causing high-heat electrical event.
Solution:Check for missing insulation.
Check screw terminals for signs of high heat and burning >> tighten screws.
Replace both thermostats using detailed instructions given on link below.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.htmlIf the problem continues after replacing thermostats, more troubleshooting is needed:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.htmlFor more self-help information about your electric water heater:
http://waterheatertimer.org/Do-it-yourself-water-heater-timer.htmlFor more help, add a comment and I will respond
No, on my last water heater it take about 5 minutes for the cycle to warm up but on this one it takes almost 8 minutes is there something or a knob to lower the time?
Iand same have rheem forced air gas water heater, 50 gallons and the cycle to heat the water is longer than my last residence subsequently my gas bill is double from what I used to, with the same amount of people, I was wondering is there a valve that you can adjust to limit the gas flow in order to save some money or any other way to lower the gas bill?
Thanks
