20 Most Recent
Rheem Paloma PTG-74PVN / RTG-74PVN Natural Gas Indoor Questions & Answers
I have a paloma tankless water heater about 3
I had the same problem with my Paloma a year and a half after installation...contacted Rheem customer service (800-432-8373) and they recommened a local installer in my area. The technican diagnosed the problem as the "flow control valve"; he managed to get Rheem/Paloma to cover the part under warranty...I only had to shell out the money for the install.
I only have a 1/2
Ask the local council what the incoming water pressure is you may be able to get a water reg on the incoming line to boost pressure .
How do I bleed the gas line???
Sometimes this can be done by turning the ignition key a few times, not all the way to start, just off and to the on position before engaging a start, you will here a noise for a second that's the fuel pump sending fuel to start car, so after a few clicks it builds up the fuel pressure, air is bled out naturally. ... hope this helps ?
Paloma tankless, gas, water heater, error code C7 76
If you look on the left hand side of the burner control module you'll see 4 capacitors - the capacitors have most likely failed...pretty sure anything code 76 is P/S failure. It may also be covered for manufactures defects. If the cap is blown..the top will be slightly raised as apposed to flat like the other nearby caps - they are called top blow capacitors...the damage should be evident.
