SOURCE: Belkin N Wireless Router doesn't connect to Modem
If router is brand new you should have a set up disk. the set up disk will walk you through it or you might log onto Belkin site to see a walk through set up. If you can access internet from modem to router to internet. That means router is functioning properly. To go completely wireless you will need to secure your network and setup your access codes. Definitely use the setup disk to do this. A unsecured wireless network is a nightmare waiting to happen. Good luck
SOURCE: Blinking orange light
if you got an orange light to the router, It means that there's no Internet connection or not working from the router. I might advice you to check the Internet connection from your ISP, then check the configuration of your router or you might needing to reconfigure the router.
SOURCE: Belkin N Wireless Modem-Router F5D8633 drivers
Just hook it all up, and push and hold the reset button in the back of the router for 10 sec..
Then unplug your internet box, [cable/DSL box] and plug back in,
The internet box will send a IP to your router automaticly.
[If it dont work unplug power from both boxes, then back in but plug the internet box in first..]
done..
if your useing wireless this will not be setup with a password to join, and will be open to neighbors,,
If you want to go to the next step and setup a password to join, you can do this with out the cd also, but get it working first and hit me back
SOURCE: Modem router light blinking (no wireless connection) F5D8631-4
Try restoring the Belkin back to the factory default by powering up the Belkin and pressing the RESET button on the back of the Belkin for 7 secs. Then connect a LAN cable from the computer to the Belkin, open IE browser and type the configuration IP address and configure the wireless settings ie. SSID, encryption etc. The computer wireless cards will need to be configured with the Belkin wireless settings to allow them to communicate with the Belkin.
SOURCE: Belkin F5D8236-4 Wireless Router will not connect
1) With direct connect with modem, check the IP address and default gateway.
(I came across such a modem, it gave default gateway as 192.168.1.254)
I also had the doubt of configuring as a dynamic connection
But it won't work!
Contact your ISP to completely bridge the modem and configure the dsl modem as PPPoE connection with correct username and password.
Finally connect the modem to router and do a complete network power cycle, i.e.: Unplug power from router 1st, then power from modem, unplug the telephone line and now do the exact reverse process... Plug back the tel. cable, then power to modem... now WAIT for lights on modem to come back, then plug in the power to router. This will surely work.
