Hiya
my servis M6755B door wont open and when i start a cylce it starts and then stops straight away
DOES ANYONE NO HOW I CAN AT LEAST GET THE DOOR OPEN AND GET THE WASHING OUT
THANKS
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
