Computers & Internet Logo
Posted on Apr 06, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Compatibility problem with windows XP
I ve bought lenovo s10 laptop with registered windowsXP.I am having problem with installing unregistered softwares like MS office2003 or any other software.can i use unregistered software.
Anonymous
Level 3:
  • Master 449 Answers
  • Posted on Apr 06, 2009
Anonymous
Master
Level 3:
Answers
449
Questions
Helped
271492
Points
1363
Yes, you can use unregistered version
Why is Fn + F5 key function not working?
You probably have to download and install Lenovo Energy Management.
If you have Windows 7, you can download from this link: http://download.lenovo.com/UserFiles/Driver/en/Downloads%20and%20Drivers/S10-3/IN1EGC26WW5.exe
Use this link if you have Windows XP: http://download.lenovo.com/UserFiles/Driver/en/Downloads%20and%20Drivers/S10-3/XP/IN1EGC22WW1.exe
Save it to your harddisk and right click and run as an administrator to install.
I have purchased lenovo g570 laptop and installed windows xp in it but i m unable to install audio drivers in it. i have downloaded the audio from the website, while installing it is showing the message...
Sounds like you've downloaded the wrong driver. Make sure you download the driver that is for your operating system. If you purchased the lenovo and installed windows XP, what did it have on it when you purchased it, because all systems come with an operating system, unless you bought if from a jack leg or second hand where they wiped it.
How to install drivers for my lenovo s10 ideapad webcam (1024x600)
goto website: http://consumersupport.lenovo.com/us/en/DriversDownloads/drivers.html
I've bought a new laptop lenovo S10 windows XP I am trying to instal Yahoo won't install anything not sure why can you please help me With many thanks Laura Deloris
Follow link to install yahoo
http://in.messenger.yahoo.com/
If fails let me know the error message you get at the time of installation
Hi All\r\n\r\nReq. to all please provide me confirmation regarding "one key recovery" firstly i must tell you i am using netbook lenovo "s10 series windows 7, now if i format hard disk(C:)...
Hi Nishant,
I saw you post about the One Key Recovery on your S10-3 system and I would like to Help.
You mentioned that you have an S10-3 system and that it has Windows7 on it and that you want to install Windows XP on it.
I guess that can be possible as long as you do not delete / format the partition where the One Key Recovery is located your One Key Recovery can still be utilized once you may need to set the system back to factory defaults, the Partition where the One Key Recovery will sometimes be name Lenovo Recovery Partition and cannot be seen in windows since it is a hidden partition only seen when doing an installation of windows using a retail Windows Installation cd.
Just to add about the OKR or One Key Recovery once you downgrade to XP and you use the One Key Recovery it will restore the system back to factory defaults then windows7 will be the operating system again on your s10-3
2answers
Fomratting to original OS
Lenovo doesn't provide restore CDs... and the S10 don't even have CD drive. Since you install XP in new partition, probably Vista is still there? Try using Vista DVD (I assume you are using external CD for S10). Boot with Vista DVD and choose the repair option if available. If not, you may need to go to Lenovo support to get the S10 restored to original state.
Bluetooth problem
It will only work if you reinstall windows with the same discs that came with the laptop as it has the right drivers...
1helpful
5answers
How to uninstall Vista and load XP in Lenovo Y510 Ideapad
Several points:
1. Although you may prefer XP to Vista, it is probable that you are simply
more familiar with it. If you would give yourself some time to become
accustomed to Vista, you might find that you like it. I know I do.
2. You can't literally "uninstall" Vista, but if you want XP instead, you
simply do a clean installation of XP the normal way. That will format the
drive, removing whatever is on it.
3. Do you already have a copy of XP you want to install? Did it come with
your old computer? If so you need to be aware that OEM versions (such as
those that came preinstalled on computers) are permanently tied by their
license to the first computer they are installed on. If that's your
situation, your copy of XP is not available to be used on your new laptop.
4. Over and above the licensing issue in point 3, many OEM version of
Windows XP are BIOS-locked to the computer they came with, and you actually
won't be able to install it on a different one.
5. You should check with your vendor to be sure, but the warranty on your
new computer may be voided if you change operating systems.
6. Laptops often have special drivers they need for components within them.
Your new laptop undoubtedly came with all the drivers needed for Vista, but
it didn't come with the drivers needed for Windows XP. Finding and getting
the drivers you need may be a problem.
If I were in your shoes, I'd stick with Vista.
If you still want to uninstall:
The normal way to "uninstall" any operating system is to format
the hard drive and install a new OS of your choice.
After backing up any data you wish to transfer to the new OS
installation, simply boot from the WinXP Home installation CD. You'll
be offered the opportunity to delete, create, and format partitions as
part of the installation process. (You may need to re-arrange the order
of boot devices in the PC's BIOS to boot from the CD.)
HOW TO Install Windows XP
http://support.microsoft.com/default...B;en-us;316941
http://www.michaelstevenstech.com/cleanxpinstall.html
http://www.webtree.ca/windowsxp/clean_install.htm
Then the backed up data can be restored and applications re-installed.
You can even try a dual boot, where you have both Vista and XP on the same system. Click HERE for pictorial guide.
5helpful
3answers
Cant access HP DIRECTOR facility.
http://www.fix-all-dll-errors.com/xmlparse.dll/
Here is the solution for your problem.Visit the link and click the button"Fix dll errors now" and your problem will be solved.
Grand Canyon Tech
Grand Canyon Tech
