Installing driver side interior door handle
pull the inner panel off by first un screwing the two screws located on the handle portion of the panel(they may have plastic hadeaway covers over the heads) then remove the window rolldown handle(if so equipped,manual window)then pull the plastic trangle from the inner of the mirror(this little tri angle keeps the trim down and secure on the door. then pull the palnel directly out there are small clasp pins in behind the panel try not to break these(but they do sell replacements at your local auto store) you will have to get ALL of these free then wiggle the panel up releasing it from the inner shell of the door and and window. you should now have a clean view of the handle. you will now need to droll out the rivit holding the handle to the inner steel of the door. pull the handle forward and it should be released from the inner steel now there clips holding the "rods" to the handles back side, they should have a little piece clipped to the rodto un clip these you need only push them off with your thumb. then replace handle with the new one, and uce a large steel screw to secure the handle when replacing back on door.
