SOURCE: Where is the fuse on a Frigidaire microwave
The fuse is inside the control panel. In order to get ot it you would have to be knowledgable on how to take the control panel off.
SOURCE: my frigidaire gallery over range
It may be a blown thermal cutout / thermostat on either the magnetron or oven cavity.
You can find
helpful exploded view diagrams and order parts by entering your full
model number from the tag on the oven here.
At
our Web site,
we have a video
available showing how to remove a typical
over the range grille and control panel assembly in under 5 minutes.
Then you can access most of it for testing and part replacement.
We're
happy
to help you with free advice and we'd appreciate your thoughtful rating
of our answer.
SOURCE: Where is the fuse on my microwave Electrolux PLMV169DCD located?
We have three service manuals covering the PLMV169 series, which you can download free:
http://www.microwavedisplay.com/plmv169dcc_sm.pdf
http://www.microwavedisplay.com/glmv169_plmv169_sm.pdf
http://www.microwavedisplay.com/glmv169_plmv169_late_prod_sm.pdf
They're all pretty similar.
You can usually find parts from the Pros here.
If not, contact Electrolux at the phone number on the front of the service manual.
It may be the C/T fuse (thermal fuse located above the magnetron) or the oven cavity thermal cutout, located on the top of the cavity.
Accessing these two parts for testing and possible replacement will require you to remove the oven from the wall.
If
so, the installation instructions are very handy, and it's best to have
two people since the microwave can be heavy and awkward.
You can
download Electrolux / Frigidaire owner's manuals and installation
instructions here.
It may also be that there was a power surge which damaged the control circuit board, activating the built-in surge protection.
This is not resettable. The circuit board has to be repaired. We do that for $39.95, details here.
We're
happy to help you with free
advice and we'd appreciate your thoughtful rating of our answer.
