Vizio P42HD Television Logo
Anonymous Posted on Aug 02, 2013
The screen lags only on the right side of my screen
  • Anonymous Aug 02, 2013
    its just blue for about 6" from the side and all the way down
How do you record your gameplays without lags?
Lags and freezes sometimes are caused by your PC CPU's capacity, your internet connection, and the screenrecorder you use. I suggest you check these reasons. Cyberpunk 2077 is such a burden to your PC's hardware. What screenrecorder do you use? Maybe you try the light one.
Here you can check this article. How to Record CyberPunk 2077 on Windows Computer with No Lag
Hope it can help you.
Hitachi LED tv image lags.
Hi, The TV needs updating & you can do this easy yourself. Please leave me feed back: Malcolm Campbell, Thanks.
Lagging alot in a Online Flash Game, any Help?
Try clearing your catch and your temporary files.
Or you can download program online that do that for you. Try "Advanced System Care 6". That will make your computer much much faster and better.
I have a toshiba 40rv525u. Turns on. Screen looks weird. Right side of screen lags the left side kinda like the right side Takes time to charge up or somethibg. Black fade gradient down the middle. Looks...
It sounds to be a back-light fault. Contact any service technician. ANY PERSON ATTEMPTING TO SERVICE, FAMILIARIZE HIMSELF WITH THE CHASSIS AND BE AWARE OF THE NECESSARY SAFETY PRECAUTIONS TO BE USED WHEN SERVICING ELECTRONIC EQUIPMENT CONTAINING HIGH VOLTAGES. USE A SEPARATE ISOLATION TRANSFOMER FOR THIS UNIT WHEN SERVICING.
Toshiba Dynadock 3.0 mouse and screen lag
You are right, it should not...Check your device manager and see if there is any problem listed there (the little yellow exclamation mark) against the Dynadock. Also check on Windows site if your device is listed as compatible with Win 8 ... Just some ideas, hard to tell just by description.
Sony KDL-52WL130 Dark and blurry on left side of screen . Also vertical lines on left side of screen
The TV requires thorough servicing and this might require attention by a qualified service technician.
1helpful
From the time i hit button and the time the picture actually takes is way to long i miss the pic how can i fix this
This "shutter lag" is a common situation with most compact point&shoot cameras. The camera has to do a lot of work when you press the button, including acquiring focus, metering the exposure, and switching the circuitry from displaying on the screen to recording to memory. More sophisticated (and more expensive) cameras have more hardware to reduce this lag.
You can reduce the shutter lag by anticipating the action. Press the shutter release button halfway to focus and meter. Keep it pressed halfway until the right moment and then press it the rest of the way.
Pixels aren't refreshing correctly in upper right hand side of screen
You might have a Service Co. come out and look at it. It sounds like the Z module is not doing it's job of erasing all prior images after a scene change. Some models there are adjustments for that internally. ( only for a tech ) Start a paper trail now.
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
