SOURCE: I would like to find a driver for epson perfection scanner 1240u
I had the same problem.
First solution: Use Ubuntu instead, it works great with 64 bit.
Second solution: Download the full version of vuescan from a torrent site. (This program has a driver that will work with thousands of scanners) The demo version puts watermarks in your scan. Why pay for a program that makes your scanner work when Epson should get their lazy ***** to work making drivers for 64 bit?
SOURCE: I can't find a driver
A Windows 7 64-bit driver for your scanner is not available from Epson.
Try drivermax.scan for driver. www.drivermax.com
or
Try driver fetch http://cdn.blitware.com/static/download/blitware/2.5.1.0/driverfetch_setup.exe .
SOURCE: I need a driver for my epson 1200u photo scanner.
I used this link today 7-24-2012 and it worked like a charm.
http://www.box.net/shared/5rxsn87mqr
A huge THANK YOU to the person who did the work that Epson
should be doing.
Without the scanner turned on, I downloaded the file, unziped it
and extracted the files. I then ran the .exe
After that I turned on the scanner and let Win 7 install the device.
Simple as pie.
