1999 Dodge Ram Logo
Posted on Mar 31, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
99 dodge ram 1500 4x4 5.9l tranny problems
I recently bought this truck and problem didnt appear on test drive. I did start to notice that when i place the truck in drive and barely give it gas, it seems to jump from first to second gear like it cant decide which to shift into, when i give it a good firm press on the pedal it seems to work fine. This only happens from first to second gear. I changed fluid and filter, no help. Any suggestions
99 Dodge Ram 1500 Sport 4x4 5.9L Automatic Transmission
-Jim
  • dawgk91 Mar 31, 2009
    Thx for the input, but wouldnt that cause it to do it all the time, there are times when i will take off and works just perfect, then other times when it will be undecided on which gear first or second when im barley touching the pedal. I was leaning towards the throttle body adjustment, or even replacing the govenor speed sensor and solonoid? I appreciate your quick response. any other suggestions would be appreciated. Thanks again.
    -Jim
Joe Lamb
Level 3:
  • Master 463 Answers
  • Posted on Mar 31, 2009
Joe Lamb
Master
Level 3:
Answers
463
Questions
0
Helped
204459
Points
1646
Take a look at the down shift cable and make sure its not broken especially were it connects to the throttle linkage.And maybe try cleaning the electrical plug that plugs into the trans.Its about a 7 to 9 wire plug.They tend to collect water and short the wiring out.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_a3369546f8067589
Anonymous
Level 2:
  • Expert 48 Answers
Anonymous
Expert
Level 2:
Answers
48
Questions
Helped
37658
Points
116
The ole sawdust in the gear box trick eh? Just kidding. I had an almost exact problem in a Honda I owned once. I took it to the tranny shop to find out the 'spider gear' was missing teeth/torn up. The most likely cause of this problem is Neutral Dropping. A Neutral Drop is when the vehicle is in neutral whilst revving, and then dropped into gear. It is one of the worst things you could do to an automatic transmission. It is likely the previous owner had too much fun with it.
I hate to be the bearer of bad news but the bill for me ended up being around $3k. You have a fairly common truck. Check out the local junk yard to salvage a tranny. Or, an excellent resource is www.car-part.com
Keep me posted!
1helpful
99 GMC suburban k1500 won't move in any gear
Sorry but it sounds like you have an internal problems. I have owned 4 different suburans and each have had transmission problems.
1999 5.2 Auto 4WD Dodge Ram 4WD problem
take it to a service shop you trust,or take it back to where you bought it and get the service records on the truck,and get the phone number to the past owners, and also get a carfax on the truck,I hope this helps you.
99 dodge ram automatic, pops in and out of overdrive every couple of minutes while on a level road using cruise control or not.
OD is faulty and may be called for a rebuild. There is an actuator on the tranny you can test with a vacuum pressure tester or ohmmeter depending on if yours is vacuum or eletronically activated.
I have a 99 dodge ram 2500 cummins, the rear end recently started chattering when turning, especially noticeable off the start, i did clean out my rear diff and added diff fluid to the bottom of the hole,...
MORE THAN LIKELY YOU NEED TO ADD THE FRICTION MODIFIER TO THE REAR AXLE FLUID..THIS TRUCK CALLS FOR 80W90 GEAR OIL AS WELL..I HOPE THIS HELPS..HOPEFULLY NO DAMAGE HAS BEEN DONE TO CLUTCH PACKS IN CARRIER
2answers
2helpful
2answers
My transmission appears to be slipping from gears
first check the level of the tranny fluid the truck needs to be running and in nutral if you have fluid it is probably the modual,the shift control modual comonly goes out the dealer will tell you you need a new transmission take your truck to a good transmission shop and have them check the modual tighten the bands and flush the transmission I had the same problem and that fixed the problem, the cost was around 350.00 also check to make sure that you dont have any leaks in your tranny lines. hope this helps
200 dodge ram stopped running and will not start.
Try testing the map sensor. This would cause the problems you say your truck has.
Just replaced tranny in 99 dodge ram 1500. Its starts doesnt stay running, cuts out. Could this be a vacuum line? Help
if it will stay running if you kep the rpms up try driving it a while. the pcm may have lost its memory for the idle control and needs time to reset it
2answers
Dodge rams plagued with tranny problems
I owned a 96 ram and all I can say is "DON"T BUY ONE"! I bought mine new and after 50 K, I replaced the rear end gears, at 58 k, the transmission was replaced, at 65 k, the fuel pump. I then bought an extended warrantee just in time for the first AC evaporator. Then after 85 K, another AC. After 120 K, a second tranny and a replacement vehicle! I am not normally ******* cars nor trucks and now own a Subaru that is perfect as well as a Corvette!
Top Dodge Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Dodge Expert? Answer questions, earn points and help others
