I have a Netgear WGPS606 that i have 2 printers connected to. The one printer prints fine with it, but the Dell AIO 962 will not print.
The print server connected to it without any problems, but when i send a print job to that printer it just doesnt print, and i get no errors, and then the print job disappears from the printer screen on my laptop as if it were printed.
I have installed my other printer which is a Brother 2070N and it works fine.I have installed my other printer which is a Brother 2070N and it works fine.
You can't post conmments that contain an email address.
I have a samsung notebook without a place to insert a disc and need to print files from my e-mail using a dell aio 962 printer how do I do this without using the software disc that came with the printer
Make sure the printer has been connected locally first and that the print drivers have been installed. This should then allow you to add the printer via the set up.
Hi, visit the link below to check the compatibility list of this print server. If your printer is not listed then it means that it has not been tested with this print server and there is equal chances for its nonfunctioning with the print server.
for further support with any netgear product visit my.netgear.com
Vista is tricky when adding networked printers.
Add printer by using a local device, not a networked device. Assume the printer is connected locally to the machine.
Check your antivirus software, mine blocked all comms with my printer after it was updated! i had to dig into the antivirus prog to turn it back on again..no warning, nothing...
Yes.
The print servers really don't care what kind of printer is connected to it.
They are simply a device that carry signal from your computer to the printer.
First, make sure that you can print with the printer connected directly to your computer using a usb cable.
- Make sure the printer driver is installed and you can print with a direct connection - Get the print server's IP Address, NetGear should have already provided you with this info. - If your'e using windows xp, go to control panel > printers and faxes - Right click on the printer icon and go to properties - Click on the PORTS tab - Click on ADD PORT - Highlight Standard TCP/IP Port then click on New Port - Click next - Input the WGPS606 IP Address - Print a test page...
Results of attempting to connect the Netgear Wireless Print Server WGPS606 and the Canon MF6550 multifunction laser printer. I was on the phone for several hours last evening (March 9, until about midnight EDT) with a very competent support agent from Netgear (actually in the Philippines). The Netgear setup Wizard software would not connect the Print Server to my Verizon FiOS wireless G router automatically, so the Netgear support agent walked me through it manually. The Print Server connected that way, for sure. Then we manually attempted to connect the Print Server to my Canon MF6550 and subsequently, my HP 932C Deskjet. Neither printer is on the WGPS606 compatible list, nor is either on the known incompatible list. Now we know - both printers are INCOMPATIBLE with the Netgear WGPS606. I bought both the Netgear Print Server and the Canon MF6550 at Staples on Sat., March 8, 2008, based upon the assurance from Staples staff that it would all work. The question now is whether ANY brand of wireless Print Server will work with the Canon MF6550, or do I have to return this printer and get either a Canon with built in networking (ethernet or wireless) or switch to the Brother equivalent (MFC 8870DW). If I get a (multi-function) printer with built-in Ethernet networking, does the Ethernet capability bypass the USB incompatibility problem, or will the problem remain?
